Clean your IAC
Old 02-05-2012, 01:52 PM
TWIN CAM 96's Avatar
TWIN CAM 96
TWIN CAM 96 is offline
Default Clean your IAC
Best thing I found to clean your IAC Sensor is CRC Mass Air Flow Sensor Spray Cleaner for about $8.99 4-5 short blasts in the sensor hole while cycling the sensor with a lint free cloth underneath the sensor and also clean your Induction Module after with CRC Throttle Body & Intake Cleaner Spray @ 5.99 what a difference my SG runs like new! can buy both at Napa or your local parts store.
Old 02-05-2012, 02:24 PM
iclick's Avatar
iclick
iclick is offline
I've saved your suggestion. Are you cleaning on a schedule? I did that a while back when I was trying to track-down some idling issues, later linked to the TPS, and used WD-40 and maybe solvent (Naphtha) as well. Both are good at cutting crud like that which forms in the IAC orifice, but the product you describe sounds like its made for use in that area.
Old 02-06-2012, 09:59 AM
TWIN CAM 96
Yes it is made for that I sure wouldn't want to clean with a harmful product and ruin the sensor. Maybe WD-40 is also a good product to use not sure!
Old 03-20-2012, 02:10 PM
CSS_FXD's Avatar
CSS_FXD
CSS_FXD is offline
Can you or someone post a pic of the IAC and how to clean it?
Old 03-20-2012, 02:25 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
Great idea....It would be an awesome addition to the DYI archives....
Old 03-20-2012, 02:58 PM
rjmac53's Avatar
rjmac53
rjmac53 is offline
agree...
Old 03-20-2012, 03:09 PM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
Remove your air cleaner and the IAC will be right behind it attached the intake manifold.
Old 03-20-2012, 03:41 PM
simpkinst's Avatar
simpkinst
simpkinst is offline
Whats an IAC Sensor and why do I need to clean it?
Old 03-20-2012, 03:58 PM
2heritagespringers's Avatar
2heritagespringers
2heritagespringers is offline
I had all kinds of prpblems with an erratic idle, cleaned IAC, didn't help. Changed TPS, problems gone, even decel pop is gone now. Not sure TPS did that but no more pop.
Old 03-22-2012, 01:09 PM
TWIN CAM 96
It senses air coming into your throttle body and gets dirt & crap lodged in it.
Should be cleaned once a year or so. It will improve your fuel mileage & idle by cleaning it.
IAC = Idle Air Control
Quick Reply: Clean your IAC
