New for Road King: Independent control of passing lights
Old 02-04-2012, 05:27 PM
HalfFast's Avatar
HalfFast
HalfFast is offline
Like DH2683, I did my own only I didn't cut any wires.
1-Stripped a 1/4" section of insulation off of the accessory power wire coming from accessory switch #4 post.
2-Used inline splice crimp to attach a short piece of #16 wire into wire from the #4 post and covered it with liquid electric tape.
3-Unplugged the wire from the #1 post on the passing lamp switch and plugged in the new wire I spliced into the accessory power wire.
4-Taped over the plug I had removed from the #1 post of the Passing Lamp Switch.
Done in a 15th of the time you guys are going to spend and no headaches.
By the time you guys remove your accessory switch and perform the necessary steps required by moco to install their harness, you will wish you had saved your $29.95
Old 02-04-2012, 05:29 PM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,518 Likes on 3,048 Posts
I rode home one night on my '98 Ultra w/o a headlight and passing lamps only.
You'd be amazed at how much light they DON'T provide. But for other's visibility of the bike I think it's a good idea.
Old 02-04-2012, 05:39 PM
TaterSaladonaRoadking's Avatar
TaterSaladonaRoadking is offline
What a waste of $30. This ia 5 min mod
Old 02-04-2012, 05:42 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
TheGrandPoohBah is offline
Received 2,523 Likes on 1,420 Posts
Originally Posted by dh2683
Yep Simple jumper wire & saves your cash.
Yep, that's the way I plan to do mine when I install the Phase 7 LED's when they come out. Doing the "Big Light Thang" all at once.
OP, I never noticed that switch before, may appeal to some.
Thanks for posting.
Old 02-05-2012, 01:54 AM
Black_Hog's Avatar
Black_Hog
Black_Hog is offline
Looks like the passing lights will work when the ignition switch is on accessory.
From the instructions: Turn the ignition key switch to ACCESSORY. The headlamp should turn OFF. Operate the auxiliary lamp switch on the fairing cap ON and OFF. The auxiliary lamps should turn ON and OFF with switch operation.
My rear turn signals stay on when the ignition switch is on accessory since I put the Running, Brake & turn signal wire harness on.
That will kill the battery in no time if you leave the spot lights on when listening to the radio and the ignition switch is on accessory.
Old 02-05-2012, 05:15 AM
Dr.Death's Avatar
Dr.Death
Dr.Death is offline
Originally Posted by Kbore
Either way, HD or nip and tuck, thanks for taking the time to post- great info!
Same here. Great thread man!
Old 02-05-2012, 07:28 AM
Pa-Rider's Avatar
Pa-Rider
Pa-Rider is offline
https://www.hdforums.com/forum/attac...n-untitled.jpg
Here is what I did years ago. Simple & save your 30.00 bucks.
I used that very schematic when I installed mine. Easy and done. Aux lights stay on as long as the switch is on. Hardest part of that job was figuring how to get my dang lock back in and working properly. (first time taking it all apart, now it's easy..)
Old 02-05-2012, 07:37 AM
green53's Avatar
green53
green53 is offline
I have a police glide, and the aux. lights aren't working, I guess the de-commissioning was only partially done. I'm not sure what switch is used on the cop bikes, I have a red button on the brake side that is for pursuit but it doesn't do anything right now. This $30.00 switch might be perfect for my bike.
Old 02-05-2012, 07:58 AM
reesestewww's Avatar
reesestewww
reesestewww is offline
Nice find! That along with the new Truck Light Phase 7 LED setup....
Old 02-05-2012, 08:25 AM
dh2683's Avatar
dh2683
dh2683 is offline
Waiting for the Phase 7 Truck-Lite led headlight to become available also.
Quick Reply: New for Road King: Independent control of passing lights
