2012 FLHTK CB and Radio Antennas
Old 02-02-2012, 09:46 PM
Concours's Avatar
Concours
Concours is offline
Default 2012 FLHTK CB and Radio Antennas
Dumb question of the day .. is there supposed to be a difference between the CB antenna and the radio antenna on a 2012 FLHTK? They look the same, and they have the same number at the base of each.
If they're are in fact the same antenna, how do you tune the SWR for the CB?
Curt
Old 02-02-2012, 09:56 PM
Hakogs's Avatar
Hakogs
Hakogs is offline
Question
one should say am/fm (left side and cb on right . there are a difference in the frequencies of the two
SWR ? Stands for what?
Old 02-02-2012, 10:46 PM
12limited's Avatar
12limited
12limited is offline
Default SWR = Standing Wave Ratio...
Curt
Good question, not dumb at all...but I know the CB antenna on my 12 limited is on left rear of the bike... I never use my CB...not real sure how to adjust it on this one. I removed the liner from the tour pack and you can see the coax connection on the left side and a single wire to a screw for the right side so it has to be the AM/FM.
Now is there a difference in the antennas?...not sure, I have not looked at them that close. Maybe there is antena tuner close to the antenna that is matching the impendence.
I remember in my outlaw CB kicker days on most of the antennas that looked simular to these we have...there was a trim pot in the top of the antenna usually under a slip-on rubber cap...to tune the reflection. I am out of town and not around my bike now to look at them close to see, but I doubt there is one there.
It never occured to me till you asked this question. I got an old SWR/watt meter...I need to see how bad it is off.
Ask your tech at the HD shop to check the SWR...see what kinda looks you get.
It will be a week of so before I get back to my bike to look.
Old 04-12-2012, 10:51 PM
beeman's Avatar
beeman
beeman is offline
So which antenna to which side? 2 posts above conflict with each other. My service manual does not specify which antenna to what side. I have both 2009 and 2011.
Old 04-13-2012, 07:17 AM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
looking at the bike from the back, the CB is on the left, the AM/FM on the right
Old 04-15-2012, 06:31 PM
iron buffalo's Avatar
iron buffalo
iron buffalo is offline
Default Antenna
On my 2012 FLHTK and I asked the Harley Shop, If you sit on the bike the CB in on the right with AM.FM on left.
Old 04-15-2012, 09:05 PM
vaham's Avatar
vaham
vaham is offline
once again, as earlier in the thread, the two last posts contradict one another..
Old 04-17-2012, 12:07 AM
White Ice's Avatar
White Ice
White Ice is offline
If you look at the wire to each antenna you would assume that the CB is on the left (clutch side). It isn't. The AM/FM is on the left, the CB is on the right. To verify - turn your radio on (not the CB) and disconnect the left antenna. Each antenna is marked at the bottom.
Old 10-31-2012, 09:34 AM
wrangler1945's Avatar
wrangler1945
wrangler1945 is offline
Stage I
Default Antenna Identification
Your observation is correct and your interpretation is incorrect. The Harley CB antenna is a no ground plane antenna. The AM/FM antenna is the antenna with the coax. There is a coax connector on the right side of the bike looking from back to front which can be disconnected in the tour pack to make SWR reading. That is for the CB antenna. The reading that checked with the HD dealership has it correct.
Long lonesome highwayman
11-02-2018 07:19 PM
Charlie Fogg
02-25-2015 07:29 PM
ke5rbd
2014-2023 Touring Models
08-13-2014 05:52 PM
zoozoo
05-08-2014 01:47 PM
Gonzy
Audio Systems
11-24-2013 11:18 AM
Quick Reply: 2012 FLHTK CB and Radio Antennas
