Tps problem I think
Old 02-01-2012, 08:38 PM
MILLER41143's Avatar
MILLER41143
MILLER41143 is offline
Default Tps problem I think
I just started my bike after installing heads cams and throttle body and new tmax
When I start the bike it fires up just fine but when I go to give it gas it dies every time. The guys at thunder max are thinking that I have a bad tps module
Has anyone else ever experienced this
Old 02-01-2012, 08:39 PM
soft 02's Avatar
soft 02
soft 02 is offline
Gone through 3 TPS sensors and never did that.
Have you tried disconecting the t-max? Gotta be something you over looked. Did it have an issue prior?
Old 02-01-2012, 08:53 PM
MILLER41143
No prior issues but I did all this work at once. I haven't disconnected the tmax. On the tmax gauges screen it says raw fuel 1. They say it should be around 75 and jump to as much as 200
Old 02-01-2012, 08:54 PM
klaybus's Avatar
klaybus
klaybus is offline
If your talking about the tbw setup every time I've had an issue it would idle but not rev up much above 1200 rpms plus or minus.
Old 02-01-2012, 08:55 PM
soft 02's Avatar
soft 02
soft 02 is offline
No TBW in 05.
Old 02-01-2012, 09:19 PM
MILLER41143
Yeah it's cable. Just can't give it any gas at all. It just dies every time. Stock injectors still in I switched every thing from old tb to the new one from hpi
Old 02-01-2012, 09:31 PM
soft 02's Avatar
soft 02
soft 02 is offline
Maybe a bad intake leak. Fog around the intake with propane and see if it picks up rpm.
Old 02-01-2012, 09:42 PM
MILLER41143
I tried that. I squirted ether all around it
Old 02-01-2012, 10:43 PM
MILLER41143
Could I hook stock CPU back up without fuel commander and c if it will work
Old 02-02-2012, 06:37 AM
soft 02's Avatar
soft 02
soft 02 is offline
thats what I would do at this point.
Quick Reply: Tps problem I think
