883 to 1200 ignition ?
Old 01-28-2012, 02:36 PM
mrfikser's Avatar
mrfikser
mrfikser is offline
Default 883 to 1200 ignition ?
I have a carbed (2000) 883 and I am thinking of going to convert to 1200/1250 and I am wondering do I need to do something to the timing ..seems like I read somewhere that the timing is different on 883 and 1200's....
Old 01-28-2012, 08:03 PM
Scuba10jdl's Avatar
Scuba10jdl
Scuba10jdl is offline
You don't need to adjust your timing. The main difference between the 883 and 1200 units is the advance. The 883 has a higher advance than the 1200, but you can't adjust that yourself. The only way to change that is to use a different advance module.
A lot of guys run the stock 883 module and don't have any noticeable problems. The higher advance could arguably be better, but that's another debate. Unless you are really hot rodding your bike, you should be ok with the stock module/timing.
Old 01-29-2012, 09:55 AM
mrfikser's Avatar
mrfikser
mrfikser is offline
ok, thanks....I always wondered about that...is the unit solid state ???and where is it on the bike...who knows I may be able to find a used one if i know what I am looking for...
Old 01-29-2012, 12:25 PM
Scuba10jdl's Avatar
Scuba10jdl
It's solid state, and it is triggered by the timing rotor. It is underneath the riveted timing cover on the right-hand side of the engine. It's the part with the big "5" on it. To get to it you need to drill out the rivets and pull off the covers.
1HD4CJM1X4K
09-12-2018 08:29 AM
scaldwellk
10-09-2012 06:14 AM
dispela
03-14-2010 05:45 AM
Vaught221
05-19-2008 01:15 PM
jaredhd
03-13-2006 12:38 PM
Quick Reply: 883 to 1200 ignition ?
