Fuel Filter Change?
Old 01-17-2012, 03:41 PM
hoethree's Avatar
hoethree
hoethree is offline
Default Fuel Filter Change?
Getting ready to do 25K maintenance and I see changing the fuel filter is on the list. Also see the Note that perhaps only a qualified Harley mechanic ought to do this service item. I have the Service Manual and it looks pretty straight forward. Who has done it? Any tips? I am not a mechanic and this may be beyond my capability. Anyone know the rated time its supposed to take at the Dealership? Will look here on the forum for a DIY.
Its a 2010 StreetGlide, bone stock.
thanks!
Old 01-17-2012, 04:34 PM
IBHarley's Avatar
IBHarley
IBHarley is offline
There are a few threads on this with some good tips on a PVC homemade tool to remove the clamp on top of the tank but I used an oil filter wrench the one that looks like a pliers to remove it other than the ring it's pretty easy
Old 01-17-2012, 04:56 PM
SciFiGuy's Avatar
SciFiGuy
SciFiGuy is offline
Here's a thread with some pic's. Been researching myself as I'm getting close to the 25K mark myself.
https://www.hdforums.com/forum/touri...9-touring.html
Old 01-17-2012, 05:03 PM
rocknrod's Avatar
rocknrod
rocknrod is offline
Yep have done it. Very easy. No special tools used or needed, contrary to what we are told.
Old 01-21-2012, 10:47 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
TheGrandPoohBah is offline
Received 2,524 Likes on 1,421 Posts
There's a you tube video that's pretty straight forward. You'll do fine.
Old 01-22-2012, 05:42 AM
Terrabella's Avatar
Terrabella
Terrabella is offline
Had mine done by my indy mechanic. I stood right next to him to see how it was done. For him it was easy, but he struggled a bit getting all the pieces out and back in place. So, for those who have done it or have good mechanical skills, it is probable a "easy" job, but for me, there where too many things that could go wrong and it didn't look like it was something I would tackle alone. It all depends on your skill level and comfort zone. As far as changing the filter is concerned, nothing to it once everything is out of the tank, its just getting everything out and then back in the right place. What may be easy for one, can be hard for another.IMO
Old 01-22-2012, 06:27 AM
73oldsman's Avatar
73oldsman
73oldsman is offline
http://www.youtube.com/watch?v=RJvt92Mcx1Y Part 1
http://www.youtube.com/watch?v=o9bHJ...eature=related Part 2
Old 01-22-2012, 06:55 AM
pt4u2nv's Avatar
pt4u2nv
pt4u2nv is offline
I just used a screwdriver to gently tap on the ears that are on the locking ring to remove it, no tools other than that. I also did not have to remove the assembly from the tank or disconnect anything. Enough room just pulling it out far as I could and replace filter . No fuss no muss
Old 01-22-2012, 07:04 AM
Stiggy's Avatar
Stiggy
Stiggy is online now
Received 5,553 Likes on 3,058 Posts
I replaced mine at 92,000 miles last summer, ( If my car gas filter can run that long, why can't my bike?) The old filter was still fine btw.
The only problem (on my older MM injection,) was the now brittle plastic nozzle of the
pump cracked when I tried to remove the old plastic hoses. That required a little 'McGivering.'
FXDXTSport
11-27-2015 09:00 AM
Skidbiker
09-30-2015 08:09 AM
SMsgt Tom
11-06-2011 02:38 PM
FX4
05-14-2010 11:31 AM
dawg
08-20-2006 03:17 PM
Quick Reply: Fuel Filter Change?
