ABS Light
Old 01-03-2012, 11:27 PM
sixgun95's Avatar
sixgun95
sixgun95 is offline
Default ABS Light
2011 Screaming Eagle Road Glide - Twice today the ABS light didn't go out. Shut the bike off, restart, drive off then the light goes out. Any ideas?
Old 01-04-2012, 01:13 AM
jackhis's Avatar
jackhis
jackhis is offline
I hope it is not the case that you are waiting for the ABS light to go off after you turn on the engine. As the ABS light will not go off until the bike gets to certain speed, I believe it is 3 MPH, but I don't trust my old brain.
If it is the case, then it is normal!
Old 01-04-2012, 01:24 AM
HarleyLance's Avatar
HarleyLance
HarleyLance is offline
jackhis is correct. The ABS light will only go off once the bike moves forward, at about 3mph.
Old 01-04-2012, 08:56 AM
sixgun95's Avatar
sixgun95
sixgun95 is offline
It doesnt go off after 3 mph, stays on. I stop, shut it down restart, ride off and its normal. About 6 starts yesterday and it stayed on for 2 of them
Old 01-04-2012, 08:59 AM
Hakogs's Avatar
Hakogs
Hakogs is offline
Mine done this after washing it, figured I got water in the sender unit. It did go out after a while
Old 01-04-2012, 09:55 AM
sixgun95's Avatar
sixgun95
sixgun95 is offline
Just rode to work, light didnt go out. Stopped, shut her down, same story, light didnt go out. Anyone know if removing all power (battery) from the system will reset it?
Old 01-04-2012, 09:57 AM
hoethree's Avatar
hoethree
hoethree is offline
Common problem with 2010/2011/2012 models. Crimped wiring in the fairing. Ask me how I know. Warranty
Old 01-04-2012, 11:18 PM
jackhis's Avatar
jackhis
jackhis is offline
I have not had any problem with my bike (2010 limited), but I unplugged ALL the connectors the fairing, sprayed them with contact cleaner (Radio Shack), applied dielectric paste, and reconnected them.
I have 26k on my bike, and there is no electrical problem so far (knock on wood).
You only need to do once, and it's worth it!
Old 01-04-2012, 11:36 PM
EricD10563's Avatar
EricD10563
EricD10563 is offline
My bike was doing that on and off for about a year and I found the connector for the ABS sensor by the steering neck was ziptied to something and pulling on the wires, I cut the ziptie and it took the pressure off of the wire and connector and the problem went away. I looked for this problem after finding a few other people had the same issue and some even had to replace the sensor or part of the wiring harness after being pulled so tight. Of course it was easy to get to on a RK, not so sure about a RG.
Old 01-05-2012, 12:37 AM
mike 1955's Avatar
mike 1955
mike 1955 is offline
I just got a recall on the rear brake light switch from Harley on my sg. Don't know if this would show up on the abs light.
Quick Reply: ABS Light
