Fatboy Wheel and Tire Size...
Old 12-03-2011, 06:45 AM
fatboy1729's Avatar
fatboy1729
fatboy1729 is offline
Question Fatboy Wheel and Tire Size...
Hello, have a question about wheel sizes to fit my 06' Fatboy. Before I just go out and spend a fortune. I've seen it on many Fatboys but is it just an easy swap or any modifications needed to accomplish this fit. I have 16 in. wheels on the front as well as the rear on my Fatboy stock. I want to change the whole setup to 18 in. wheels and tires. I want to go with 18 x 3.5 in the front and 18 x 4.5 in the rear with low profile tires. Is this possible to do without any mods? Will it effect the stock brake calipers, rotors and pulley? Thank you for your time and any advice will be very much appreciated... Ray...
Old 12-05-2011, 01:02 PM
grbrown's Avatar
grbrown
grbrown is offline
You'll get a better response over in the Softail forum. Harleys use heavy duty tyres, with higher load ratings than most bikes that use low profile sizes, so you should check your preferred tyre brand. As a tip there are suitable tyres readily available for 17 x 4.5 rears, 160/70, used on Deuces.
Old 12-21-2011, 11:31 PM
WanaRyd Wheels's Avatar
WanaRyd Wheels
WanaRyd Wheels is offline
Sponsor
Fatboy1729,
You should be able to put an 18 x 3.5 front wheel without any problems but the maximum rim size you can go on your rear without any modifications is a 18 x 4.25. We offer wheels that you may be interested in and recommend Metzeler or Avon tires.
Feel free to PM me if you have any other specific questions.
I hope you find what you are looking for.
Ryd Safe!
[/U]
__________________
WanaRyd Motorcycle
1-888-926-2793
H.D.FatBoy
08-19-2012 12:10 AM
fatboy1729
12-05-2011 01:44 PM
scottnumero2
04-14-2011 01:35 PM
fatboy1729
11-18-2009 11:14 AM
Phat98
07-22-2006 12:13 AM
Quick Reply: Fatboy Wheel and Tire Size...
