Sponsored by: Jekill and Hyde
Evo Cam Cover Gasket
Old 11-30-2011, 09:32 PM
fastball44's Avatar
fastball44
fastball44 is offline
Default Evo Cam Cover Gasket
I have an annoying oil leak that I cannot trace. I think it might be coming from the bottom of the cam cover. Therefore, I need to replace the cam cover gasket. I have removed the exhaust and other items to access the cam cover on my 1996 Ultra with an Evo engine.
So here is my question: Can I simply unbolt the cam cover and replace the gasket? Or do I have to do anything else first, like remove the timing cover or take pushrod pressure off the cam???? Thanks in advance.
Old 12-01-2011, 05:37 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Your going to need to lift the gas tank, and open the rocker covers, and release the pressure on the pushrods via removing the rocker arms, then you can remove the cam cover.
Probably not what you wanted to hear.
Scott
__________________
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Maxton Mile World Record
4500 sq ft. facility
See us on Facebook.
Old 12-01-2011, 08:26 AM
ajayrk's Avatar
ajayrk
ajayrk is offline
Check the clutch cable for a leak at the transmission cover o-ring or a rub through under the cam cover.
Old 10-12-2012, 10:31 AM
99HarleyFXR's Avatar
99HarleyFXR
99HarleyFXR is offline
I have the same issue, can this be done any other way?
I did hear that you can pull the cover without unbolting the tank or rocker covers and pull the cover off slowly. THen the cams will come out, but they only go back in one way= so you can rock the bike back and forth slowly to get the engine turn over over slow enough to push the cams back in! I have never tried it but have heard it to be done.
Old 10-12-2012, 02:59 PM
ajayrk's Avatar
ajayrk
ajayrk is offline
I have removed the cam cover with out taking off the rocker cover in order to remove the oil pump for repair..
Use a cam cover puller and the cam will stay in place. I did this with stock springs. High lift springs may make it a little tougher to line up the dowel pins into the cover.
Old 10-12-2012, 09:15 PM
99HarleyFXR
where do i get a cam cover puller
Old 10-13-2012, 07:55 AM
ajayrk's Avatar
ajayrk
ajayrk is offline
One source is J&P Cycles. Part number 910-067.
http://www.jpcycles.com/product/910-067
I made my cam cover puller with a length of aluminum stock, tapped for a 3/8" bolt and drilled two holes to ling up with the tapped holes in the cover. Used two screws from the hardware store to screw into the cover. Turn the jacking screw and it pulls the cover off of the cam.
Old 01-08-2013, 10:20 AM
1996ultraclassic's Avatar
1996ultraclassic
1996ultraclassic is offline
Stage IV
Default cam cover
I just removed my cam cover to install new cam, remove the timing cover then remove timing then remove the cover inside sorry don't know what it's called . I used a rubber mallet tapped lightly on cam cover and id came right off.
tar_snake (02-27-2017)
wildmansam
03-31-2018 05:56 PM
Snowfly
01-12-2011 11:21 PM
55bob
08-05-2010 07:42 PM
Rojuco
02-11-2009 06:10 PM
VikingRider
Ironhead
04-05-2008 08:15 PM
Quick Reply: Evo Cam Cover Gasket
