LED Signals without Load Equalizer
Old 11-30-2011, 01:57 PM
cthagreekgod's Avatar
cthagreekgod
cthagreekgod is offline
Default LED Signals without Load Equalizer
Does anyone know if there are any negative effect to not using the load equalizer (other that the fast blink)?
I just replace both front and back signals with LEDs and they work fine other than the blink rate is fast. Will this cause any damage in the long run or can I just keep it this way?
Old 11-30-2011, 02:05 PM
07bobber's Avatar
07bobber
07bobber is offline
im just running the rear as of right now without a LE and i have the same results besides my key light coming on but its not a big deal..
Old 11-30-2011, 02:23 PM
capttxrngr's Avatar
capttxrngr
capttxrngr is offline
From what I understand, they could possibly "freeze" up on you. LEDs do not draw as much current so the load equalizer tricks the computer into thinking that they are drawing the same as standard bulbs.
Old 11-30-2011, 03:04 PM
DYJ's Avatar
DYJ
DYJ is offline
When I first installed my Aloy Art rear LED's and left the OEM fronts, they worked as they did from the factory. I think the front stock turn signals were acting as the LE. When I swapped bars and ditched the front signals all together, then they blinked fast and the key came on. I ran it that way for a full summer, 10+ thousand miles. Never had a problem. But then I saw how cheep the bad lands plug and play modual was and how it was literaly a plug in fix for my problem, so I got it and never turned back.
Old 11-30-2011, 04:30 PM
07bobber's Avatar
07bobber
07bobber is offline
Thats the le im planning on getting, how was the install?
Old 11-30-2011, 04:44 PM
biketroll's Avatar
biketroll
biketroll is offline
the Badlands LE is just plug & play 5 min. install.
Old 11-30-2011, 05:07 PM
macnab_sf's Avatar
macnab_sf
macnab_sf is offline
Edit - nevermind - found the answer
Old 12-01-2011, 11:54 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
nothing man... i had a equalizer on mine and i did not like how slow they blinked i pulled mine out to get the hyper flash. everyone i ride with says it is easier to see that way
Old 12-01-2011, 12:35 PM
DSnoopy's Avatar
DSnoopy
DSnoopy is offline
Good to know! Thinking about getting some LED for the front when I put your bars on.
jambo1989
01-17-2017 08:33 PM
jeffbetrollin
08-02-2015 04:18 AM
sdeck86
02-22-2015 04:53 AM
worthymccormick
02-06-2010 11:00 AM
ChromeJunkie
09-20-2007 06:03 AM
Quick Reply: LED Signals without Load Equalizer
