What Are First Signs of Compensator Failure?
Old 11-28-2011, 07:57 AM
pierced5's Avatar
pierced5
pierced5 is offline
Default What Are First Signs of Compensator Failure?
Noticed this weekend that when I start my bike it makes unusual noise. Sounds like it is coming from forward primary cover area, like a clunk. Is this a sign of imending compensator failure. I installed FM107 kit about 1K miles ago. Any help or suggestions appreciated.
Old 11-28-2011, 08:11 AM
bulkman2008's Avatar
bulkman2008
bulkman2008 is offline
Glad you asked that question , I am noticing a knock , not steady but maybe two or three times a minute in the rear area of the primary , it can be heard easily over the engine running .
Old 11-28-2011, 08:12 AM
Captain Itch's Avatar
Captain Itch
Captain Itch is online now
Sponsor
Pretty good indication for sure..Starter will be acting a little cranky..or uh lack of..Good luck plenty of threads on this issue..
__________________
www.Captain-Itch.com
Old 11-28-2011, 08:44 AM
honestbob's Avatar
honestbob
honestbob is offline
My compensator went out on my 08 at 30,000 mi. I thought it was a bad starter gear, but it only did it when it was hot (gas stop) It would make a grinding and hard grabbing banging noise. I waited too long and it destroyed my alternator. It made no unsual noise while running though. I am about to hit 80,000 mi. and I am sweating it out. At the first sign now I'm gonna replace it with a Screaming Eagle.
Old 11-28-2011, 09:09 AM
TUCCI's Avatar
TUCCI
TUCCI is offline
Why wait, if your in the year group and youve got a good amount of miles just get that incompetant compensator the frick outta there....i wouldnt wait for it to start tearing things up, pre-empt it and put it behind you. If my 2011 was in the year group i would have gutted that garbage out of there as soon as i read about it.
jsvt184's Avatar
jsvt184
jsvt184 is offline
I replaced my stock comp with the newest version of the SE comp a couple of months ago. I had around 20000 miles. I also thought I was having problems. Lots of noise, banging on startups and a sloppy feeling. The new SE compensator is much better. However upon taking the stock compensator out I found nothing wrong with it. It's just a sloppy, noisy component. I'm still glad I changed it out.
Old 11-28-2011, 10:35 AM
phillyrube's Avatar
phillyrube
phillyrube is offline
I'm getting the same noise on my 2005, but that has the old EVO compensator. Do those go bad?
Old 11-28-2011, 10:51 AM
mech8251's Avatar
mech8251
mech8251 is offline
Mine started to have alot of banging on startups and abnormal noise throuhout all rpm ranges. Dealer removed and replaced the clutch and drum assy., compensator sprocket and starter. The Clutch drum was missing a couple teeth along with the starter missing one tooth which explained the kicking back. The clutch assy. had a couple teeth broken off inside also. (Have no idea how that happened). I'm guessing all of this was due to my primary bearing failure!!!
Old 11-28-2011, 02:27 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Lowcountry Joe is offline
There's a lot that can make noise in the primary "area" and sometimes it's hard to distinguish. Sometimes it might be the starter/starter clutch, sometimes maybe the compensator, sometimes associated with the clutch assembly itself, and sometimes a noisy chain/worn out chain tensioner combination. Just a lot of crap that can go wrong, but for the majority of bikes never does. I hope mine is one of the majority, but I have been thinking hard about getting the SE compensator and putting it in by 2010 Ltd.
C908
10-13-2017 09:38 PM
Bowhunter61
08-12-2013 11:16 PM
eja
10-11-2009 01:10 PM
Bdub
12-28-2006 10:59 AM
Bdub
12-18-2006 10:25 AM
Quick Reply: What Are First Signs of Compensator Failure?
