slip ons vs full exhaust performance
Old 11-22-2011, 04:14 PM
rooti's Avatar
rooti
rooti is offline
Default slip ons vs full exhaust performance
I have a 2011 dyna superglide custom with rush slip ons with 2.25 baffles.
I love the sound, but I remember the dealer telling my slip ons were just for the sound and would do little for performance. How much performance difference is there in a good full exhaust. Keep in mind I do not have the cats so it is free flowing....
The best sound in a full exhaust that I liked was the vance and hines 2-1 pro pipes. Just wondering how much horsepower would I really gain over my current set up.
Old 11-22-2011, 05:04 PM
perryross's Avatar
perryross
perryross is offline
Interesting take on the subject:
http://www.harley-performance.com/harley-exhaust.html
May or may not help.
Old 11-22-2011, 05:18 PM
Shredding rubber's Avatar
Shredding rubber
Shredding rubber is offline
Slip on don't do ****
Old 11-22-2011, 05:24 PM
rooti's Avatar
rooti
rooti is offline
Well I wouldn't say that....They do give you the sound and in my case did get rid of the cats. As far as a comparision between the two...You really didn't tell me anything
Old 11-22-2011, 05:37 PM
Shredding rubber
What I meant was there is 0 power gain to be has. I have the straight shots slip ons but am buying a propipe this weekend.
Old 11-22-2011, 05:41 PM
rooti's Avatar
rooti
rooti is offline
Cool, can you let me know how the pro pipe is after you install it. Love the sound of that pipe...
You sure it's zero? You would think getting rid of the cats would at least give it a half of horsepower...lol
Old 11-22-2011, 08:04 PM
SPECIAL ED's Avatar
SPECIAL ED
SPECIAL ED is offline
If you go with some free flowing slip-ons a less restrictive AC and some sort of fuel management you can expect to get within 3-4 HP of the same set up with a 2 into 1.I've even heard some say they actually made more HP with the slip-ons than they did with their full system but that is the exception rather than the rule.Now,if you go with a 2 into 2 system all bets are off.I've heard of some making less power than the stock system.
Old 11-22-2011, 09:14 PM
nevil's Avatar
nevil
nevil is offline
From everything I've read there is more hp to be gained from a full system. How much more, if any, has a lot to do with the tuning map you're running.
Old 11-22-2011, 09:37 PM
JohnC FXDX's Avatar
JohnC FXDX
JohnC FXDX is offline
That is not true. A 2-2 system tends to give up a little torque and mid range over a 2-1, but generally makes a little more HP. You also have to tune or jet to match. If you don't, then you could lose power with either.
Old 11-22-2011, 09:38 PM
FBinSoCal's Avatar
FBinSoCal
FBinSoCal is offline
What I personally gained from my new "bassani" slip on was 2.7 hp and 7.19 lbs. of torque and that is on a stock 103" with 2>1 on stock header pipes but WITH the cat. Just did it last week. In your case you don't have a cat so I don't know how just a slip on would perform. When I had the whole system on without the cat, I'm guessing I obtained double those numbers but didn't get a chart to confirm. Within a couple of weeks I'll be putting the whole system back on (gonna get a chart this time) and will share those numbers if you are still interested. The cat saps a lot of power.
Quick Reply: slip ons vs full exhaust performance
