rake & trail
Old 11-20-2011, 09:40 AM
azwiz's Avatar
azwiz
azwiz is offline
Default rake & trail
Just looking at the spec on the Ultra and Tri Glide. The rake is the same (26*) but the trail is different (Ultra 6.69", TriGlide 3.94"). Can anyone explain?
also has anyone put a rake kit on the Tri Glide, can't believe the Ultra & Tri Glide have the same rake, trikes need more rake to ease the turning
thanks
Steve
Old 11-20-2011, 11:47 AM
ZD's Avatar
ZD
ZD is offline
thanks
Steve
Just a W.A.G., but longer trail increases directional stability... Shorter trail makes a bike a lot more reactive but easier to steer. I suspect what H-D was looking for was a way to create an easy-to-steer machine without having to tool up for a different neck/frame rake angle. (Cost savings) Hence, they left the rake alone and cut the trail to increase ease of handling, but in the course of doing so they ended up with a very goosey machine in terms of directional stability. Hence, they added the steering damper to off-set the tendancy to over-steer.
From my own limited experience with the 2011 Tri Glide, I can manage the potential oversteer now that I've got a few hundred miles on the thing. The effort to turn is fine in my case, but others who've got upper joint and/or strength challenges might find it a bit too much for long rides.
At any rate.. that's my 2 cents' worth!
Old 11-20-2011, 01:01 PM
msocko3's Avatar
msocko3
msocko3 is offline
The triple trees on the triglide are raked, they have a different part number than 2 wheel bikes and you can see the stem is located different plus the forks are 1 3/4" longer which helps increase rake.
Old 11-20-2011, 01:12 PM
ZD's Avatar
ZD
ZD is offline
I figured they'd have had to do something like that... No other way that I could see to change the trail.
Old 11-01-2018, 07:20 AM
Helmwurst's Avatar
Helmwurst
Helmwurst is offline
If your trike is squatting in the rear, like most of the earlier ones did, try adding a pair of adjustable or air shocks to the rear and raise it up level. This will improve the steering.
Old 11-01-2018, 12:11 PM
smitty901's Avatar
smitty901
smitty901 is offline
Received 9,557 Likes on 5,153 Posts
The frame rake is the same but the Tree is raked. I have a Trike front end on my 2017 RGU. The trike front increased wheel base by 4 inches. The tubes are almost 2 inches longer but with the rake of the tree is sits the same..
Old 11-01-2018, 06:32 PM
mctraveler's Avatar
mctraveler
mctraveler is offline
To help improve steering.... if turning left, for example, lock your right elbow and just pull with the left hand.....technique requires a lot less effort...... can view this on the Lehman website..o
Old 11-01-2018, 07:02 PM
talkingrock's Avatar
talkingrock
talkingrock is online now
A comfort lift kit is a must have , I don’t know if it will load the neck bearings and increase wear but it steers easier you have to be careful steering at higher speeds it turns quickly , I have the Legonds kit on mine
Old 11-02-2018, 02:32 PM
DK Custom's Avatar
DK Custom
DK Custom is offline
Platinum Sponsor
Received 3,930 Likes on 2,288 Posts
Legends does not make a Comfort Lift™ Kit. They make a standard lift kit that does not provide the additional shock angle to make the ride more plush.
We used to make a Standard Lift and a Comfort Lift™ , but have discontinued the standard. The Comfort Lift™ Kit is does everything the standard does and more. Link to details HERE.
Regarding the discussion of Rake & Trail. It can be a bit intimidating when first trying to understand it all, but there is a really good article at this LINK, by Mark Zimmerman, that gives all the technical info, but in fairly clear "English".
__________________
Kevin
DKCustomProducts.com
Call/Text: 662-252-8828
Old 11-02-2018, 04:02 PM
ultrafxr's Avatar
ultrafxr
ultrafxr is offline
Absolutely great article. Thanks for posting!
Quick Reply: rake & trail
