How to replace a softail swing arm with pics
Old 11-19-2011, 08:23 PM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
Default How to replace a softail swing arm with pics
I recently replaced my swing arm as I thought it was time to inspect the bearings, bushings, etc. with the mileage I am getting to on my bike. I am at 68K right now. I was not sure what to expect but the manual made it sound easy enough and I had a spare near new swing arm sitting here. In hindsight, I should have chromed the spare one but did not. It is definitely 20/20.
1.Put bike on lift. Depending on your rear suspension set up, either remove shocks or pivot your air ride out of the way. I did not do either first as I was not thinking, no surprise here.
2. Remove rear wheel and brake caliper. Remove splash guard.
Notice the swing arm is already off in this pic.
3.Using a 1 3/8" socket and an adjustable wrench ( I had to use an adjsutable wrench due to the True dual exhaust on the left side) Remvoe the bolt that holds the swing arm.
I found a lot of leverage is necessary on this bolt so use a breaker bar or a BIG ratchet.
Once the bolt is removed move the swing arm up and down to free the spacers and then the same to remove the bushings. Teh wing arm will not come off until you get the bushings off. Once they are off it will slide right out.
Yup same pic again. I forgot to take one at every step.
Inspect the bearings and bushings for wear. My bearings still functioned as they just came off the assembly line and the bushings looked fine, but I had new bushings and the "new" swing arm had near new bearings as well. Teh bearings are held in my a large snap ring in each side of the swing arm. I did not need to mess with them, but it looks simple enough to remove them.
Here is the bushings that hold the swing arm on. One on each side.
Slide the swing arm back into place and secure it with the bushings. You need to move the swing arm up and down to be able to get them in on both sides easily. Next put the spacers in place. Same thing for moving the swing arm for these.
Slide the swing arm bolt back in and spin the nut on the end using red loc tite. Do not tighten yet. Ensure that you have proper mvoement then tighten.
New swing arm in place
Reassemble everything else.
Total time for this job was 3 hours taking my sweet time with a friend.
Drew
Old 11-19-2011, 08:43 PM
nysdeucerider's Avatar
nysdeucerider
nysdeucerider is offline
Talking Helpful info!
Thanks Doc! Been toying with a chrome swing arm but was nervous about getting into a painfully complex procedure. Your post makes me less pessimistic, almost to the point I wanna go out and tear it apart tonight - just for a dry run! *whack*
Okay, maybe not quite THAT enthused, but you get the idea! Well done!
Old 11-19-2011, 09:11 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Glad to help. Much simpler than I thought too.
Drew
Old 11-19-2011, 09:19 PM
soft 02's Avatar
soft 02
soft 02 is offline
Thanks Drew! This is on my 100,000 mile service list.
Old 11-19-2011, 10:52 PM
04reddeuce's Avatar
04reddeuce
04reddeuce is offline
thanks for the write up.
Old 11-20-2011, 01:00 AM
thelawnmowerman's Avatar
thelawnmowerman
thelawnmowerman is offline
Nice one Drew, you guys certainly put some miles on those bikes,
Old 11-20-2011, 05:30 AM
Blk and Chrome's Avatar
Blk and Chrome
Blk and Chrome is offline
Good job Drew, not that bad a job at all. Thats one old Snap-on rachet you have there,
Old 11-20-2011, 07:49 AM
NC D'LUXE's Avatar
NC D'LUXE
NC D'LUXE is offline
Drew, thanks, I'll have to bookmark this. Swapping out for a chrome swing arm is down there on my list at some point.
Old 11-20-2011, 08:06 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
It's from 1930 and still works well. Might as well use it. The swing arm swap is one of the easiest things I have done. The hardest part was getting that bolt undone that holds it on as the it was super tight.
Drew
Old 11-20-2011, 08:34 AM
Tripp_HPjunkie's Avatar
Tripp_HPjunkie
Tripp_HPjunkie is offline
Good write up how old is that snap on ratchet?lol
Quick Reply: How to replace a softail swing arm with pics
