HD LED headlight alignment help
How is it any different than adjusting the regular light? Usually the damn bolt is so tight u can't loosen it so put 2 hands on it and move it.
My opinion is that these lights are a tremendous improvement over the stock headlight. When properly adjusted, they work just as well as the LED or Hid style lights on a car. The best description is that these lights flood your view of the road with solid light just up to the bottom edge of the windows on the cars in front of you. They really light up the painted lines in the street. When i first installed them though i got nervous because they didnt seem to do a good job at all but then noticed that they were pointing way too high and needed to be adjusted quite a bit.
The look is unique and the black headlight looks a little out of place on my Big blue pearl Lo but is growing on me. As i continue to black out the bike it will start to fit in with the look that I am trying to create.
I have a 2001 Fat Boy with a big nacelle kit. I had a devil of time getting my LED adjusted and I'm still not convinced it's 100% correct.
Basically, I had to adjust the top screw on the headlight mounting ring all the way in and the two left-to-right adjustments almost all with way out to get the beam pointed high enough where it wasn't pointed down at the road. When you do that, it makes it difficult to get the big nacelle trim ring on correctly. Am I missing something?
