Power Vision - No ECU
Old 11-08-2011, 09:26 PM
ssmith579's Avatar
ssmith579
ssmith579 is offline
Default Power Vision - No ECU
Just got my Power Vision and when I try to load a map it says no ECU detected. Any ideas? This is on a 2012 Limited.
Old 11-08-2011, 09:29 PM
soft 02's Avatar
soft 02
soft 02 is offline
Do you have an ECU?
Old 11-08-2011, 09:36 PM
ssmith579's Avatar
ssmith579
I don't think it would run well without one.
Old 11-08-2011, 09:40 PM
soft 02's Avatar
soft 02
soft 02 is offline
Yea it was a smart *** remark! I dont remember the install procedure when i installed mine. I'm sure its something simple.
Old 11-08-2011, 09:41 PM
XARAN's Avatar
XARAN
XARAN is offline
Turn on the Ign switch and the kill switch on the handlebars . The most common thing is people forget to turn on the handlebar kill switch it will read the ECU and then marry to your bike
Old 11-08-2011, 09:44 PM
DannyZ71's Avatar
DannyZ71
DannyZ71 is offline
It won't throw rice will it?
Old 11-08-2011, 09:47 PM
XARAN's Avatar
XARAN
XARAN is offline
Plug it into the plug behind the lf side cover, turn on the Ign and kill switch and it will power up. If you only have the Ign on and the kill switch off it will power up but no detect the ECM.
They are really simple just follow the screen. The first time you will have to marry it to the bike and it will save the original MAP. The select your new MAP and flash, when its done it will ask you to turn off the ign for 10 sec and your ready to go . If your PV has the newest firmwear you will also be asked if you want to reset trim values, you should do this.
Old 11-08-2011, 09:48 PM
ssmith579's Avatar
ssmith579
Hot damn, that did the trick! Thanks. Now to go try it out on a chilly 50deg night.
Old 11-08-2011, 09:49 PM
ssmith579's Avatar
ssmith579
lol, I think a tear came to my eye when it said they were married.
Old 11-08-2011, 10:34 PM
XARAN's Avatar
XARAN
XARAN is offline
Enjoy the PV, its a great easy to use tuner. If you got it from Fuel Moto the MAP should be pretty close. I tried the couple MAPS on the Dyno Jet site and they were no where as strong as the ones Jame sent me.
It took 3 subtle changes to my original MAP to get it near perfect but now my bike has virtually no decel popping , pulls strong with no flat spots and gets 42 mpg on freeway riding.
Quick Reply: Power Vision - No ECU
