Dyna oil tank
Old 11-03-2011, 05:44 PM
wyldspirit's Avatar
wyldspirit
wyldspirit is offline
Default Dyna oil tank
CAll me stupid if you want but, I am still in the learning stage here and have been puzzled by this for some time. On all of the softtail's and sporty's I have looked at, the oil tank is visible, but the Dyna's oil tank is not in the same place as the other bikes. Does it sit below the battery box or where
Old 11-03-2011, 06:09 PM
ynots's Avatar
ynots
ynots is offline
Dynas dont have an oil tank, look under the bike between the frame tubes and you will see a drain plug on the oil pan.
twerkman2's Avatar
twerkman2
twerkman2 is offline
on the bottom of the bike near trans
Old 11-03-2011, 06:16 PM
Tat2u's Avatar
Tat2u
Tat2u is offline
No oil tank, straight in the gearbox
Old 11-03-2011, 06:17 PM
Frank Castle's Avatar
Frank Castle
Frank Castle is offline
the dynas have 3 drainers ... all below as the others described.. one for the xmsn, the eng. and the primary.. and the engine oil is housed specifically in an engine sump (much like a car) rather than in a horsheshoe shapped tank below the seat like a softtail uses
Old 11-03-2011, 06:53 PM
Tat2u's Avatar
Tat2u
Tat2u is offline
Straight in the crankcase I meant to say...
Old 11-03-2011, 06:58 PM
ynots's Avatar
ynots
ynots is offline
another difference from the softtail's is dynas are a rubber mounted non-counterbalanced engine
Old 11-03-2011, 07:22 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,543 Likes on 3,794 Posts
Do the fish on bike bandit. It's bolted to the bottom of your transmission like the big baggers. Actually most mistake it thinking its all transmission. All Harley's are dry sump.
Old 11-03-2011, 08:02 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is offline
Received 4,309 Likes on 2,356 Posts
+1 on Harleys being a dry sump (crankcase) relatively speaking. There is an oil resevoir located within the the trans case. The dipstick is right hand side between the rear cylinder and starter. Check the oil when hot, and when bike is leaning on the jiffy stand. You really need to get a service manual or find an owner's manual for the bike.
Old 11-04-2011, 01:40 PM
wyldspirit's Avatar
wyldspirit
Well that answers that. Coming from a wetric cruiser some of this is foriegn to me
totemsbeard
EVO
27
11-12-2021 08:22 AM
adachris
Oil Archive (no new posts)
09-13-2019 06:40 AM
1970chopper
06-23-2009 08:09 PM
MYKSHD
04-06-2009 02:10 PM
Softail in 2007
08-08-2007 11:12 AM
Quick Reply: Dyna oil tank
