Shifter/Brake Pedal Extensions: Yes or No?
Old 10-29-2011, 03:00 PM
FenderGuy53's Avatar
FenderGuy53
FenderGuy53 is offline
Default Shifter/Brake Pedal Extensions: Yes or No?
OK, guys, I moved my floorboards out 1-inch (thanks, Soos Kit) and am now in the process of moving them forward 1-inch (thanks, HD Extended Reach Rider Footboard Pans).
For those who have done the above-noted mods, did you also opt for an extended shift lever and/or brake lever? If so, which one?
Thanks!
Old 10-29-2011, 03:08 PM
131tman's Avatar
131tman
131tman is offline
Extended pedal & pad
Old 10-29-2011, 04:14 PM
rvandy's Avatar
rvandy
rvandy is offline
1st Gear
I went with the Kury chrome floor board extension 1" out and 1" forward, and the Soft Brake slotted brake pedal. I've got an '08 CVO Ultra Classic and both pieces go very well with the rest of the bike. I drag my boards more with the 1" out, but wouldn't go back.
Old 10-29-2011, 05:34 PM
JetD's Avatar
JetD
JetD is offline
Default +1 Kurys
I 've had Kury forward/out on my last two bikes... as above, would never go back. That said, I've looked long and hard at the extended brake lever (and pedal extension) and the extended shifter arm (and peg), but not pulled the trigger yet. One reason is I'm not certain how they will function with the lowers and my size 13s..... may yet give 'em a try...
Old 10-29-2011, 06:37 PM
fathertime's Avatar
fathertime
fathertime is offline
Location: CHILLIWACK B.C CANADA: have a u.s shipping adress
i have the kury 1 inch out and 1 inch forward brackets and therefor needed to move the brake pedal forward also. I went with the slotted extended kury brake pedal but i wish it were a little longer...its at a much better angle than the stock one tho
Attached Thumbnails Shifter/Brake Pedal Extensions: Yes or No?-kury-pedal-002.jpg
Old 10-29-2011, 06:41 PM
TWIN CAM 96's Avatar
TWIN CAM 96
TWIN CAM 96 is offline
I've got size 12 feet and the stock ones are to far away now I sure would add to width or length on my SG.
EasternSP
2014-2023 Touring Models
34
07-31-2016 09:49 AM
ultraclassic53
09-03-2014 09:12 PM
dshukwit
11-01-2008 08:48 PM
Garemlin
08-21-2008 08:49 AM
CSI
06-14-2007 05:44 PM
Quick Reply: Shifter/Brake Pedal Extensions: Yes or No?
