Voltage Regulator HELP
Old 10-15-2011, 09:59 AM
trackadaptor's Avatar
trackadaptor
trackadaptor is offline
Question Voltage Regulator HELP
Voltage Regulator: 2009 FLHTCU 33k miles.... New Battery , Load Test is OK
So what are the signs the Voltage Regulator is going bad ?
Or do you have to wait till it just stops working ?
Symtoms: Start up Volts sit at 10.5 - 12.5 issh - start to ride goes to 14.3
Come to stop light: drops to 13.0 isssh then moves up to 14.0 then sometime drops to 12.0
Old 10-15-2011, 10:04 AM
dawg's Avatar
dawg
dawg is offline
Received 2,945 Likes on 1,705 Posts
Don't trust the gauge alone, take true voltage readings.
Old 10-15-2011, 10:16 AM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,535 Likes on 3,054 Posts
At idle mine's under 12 Volts. The only thing I watch for is a consistent 13.5 volts at 2000 rpm and above. No wavering needle, no varying voltage, just 13.5 Volts
Old 10-15-2011, 10:17 AM
rushbass's Avatar
rushbass
rushbass is offline
I had an intermittent low voltage problem - the volt meter would drop below 12vdc, and the CEL would come on and throw a P0562 DTC (no other codes present)... it would stay in the low voltage condition and come out after @ 1 minute... this would happen regularly...
turned out to be the voltage regulator. Good luck with your troubleshooting.
Old 10-15-2011, 11:52 AM
cooper57M's Avatar
cooper57M
cooper57M is offline
At idle my bike always read 14 volts. Never goes under that
Old 10-15-2011, 11:59 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
those readings as described seem normal.
bad regulator may display any or all of these:
allow voltage above 14.8 VDC to reach the battery ( damaging the battery)
allow AC volts to pass through
allow power from the battery to drain when bike is not running
the alternator produces about 16 to 20 volts AC per 1000 rpms.
the regulator converts that voltage ( could be over 100 volts AC) to DC and "regulates" to less than about 14.8 volts DC.
the voltmeter in the dash, is not tremendously accurate, but can give an indication of function-- if you see it reading way high or way low, then further investigation is needed.
but readings taken with a real voltmeter at the battery and alternator plug are needed for real charging system diagnosis-- again, if a problem exists.
mike
Old 10-15-2011, 01:49 PM
rushbass's Avatar
rushbass
rushbass is offline
If the bike is not throwing any historic low voltage DTC's (CEL and Low Volt Light coming on), I wouldn't work about what the gauge says... keep on riding.
Old 10-16-2011, 10:24 AM
street trucker's Avatar
street trucker
street trucker is offline
I am having the same code and problem with charging and not charging, will have to look into the regulator.
SPEEDYS_HARLEY
06-01-2017 04:51 AM
Michael Gamboa
Electrical/Lighting/Alarm
04-25-2014 06:58 AM
Lingleha
07-08-2012 05:34 PM
t059736
05-21-2012 09:15 AM
96RK
12-18-2011 06:24 PM
Quick Reply: Voltage Regulator HELP
