Rear cylinder is not firing
Old 10-03-2011, 11:14 AM
harleycharlie1992's Avatar
harleycharlie1992
harleycharlie1992 is offline
Unofficial HDF Chaplain
Received 14,630 Likes on 4,624 Posts
Originally Posted by XtremeHD
HD Charlie will that kind of eliminate the PCI if it starts on both cylinders?
if it starts on both cyls. that will point to the pc 1 as the problem
Old 10-03-2011, 11:20 AM
Mike's Avatar
Mike
Mike is offline
The ECM wouldn't be on the side compartment on the right side by the seat?
On your 07 bike, the ECM is behind the right side cover. If you have a Power Commander, it will also be under that cover.
Old 10-03-2011, 11:30 AM
XtremeHD's Avatar
XtremeHD
XtremeHD is offline
Tahnks guys I will check this informationout and get back to you, thx again
HD Dave
Old 10-03-2011, 12:18 PM
vzts4q's Avatar
vzts4q
vzts4q is offline
If the rear cylinder only did this when at idle and cleared up when you took off it probably is not any of the things mentioned by the other posters.
On the 07 and early 08 bike the Engine Idle Temp Management System had to be turned on or off by flashing the ECM
This system shuts down the rear cylinder when its temperature exceeds a certain level.
As soon as you open the throttle everything goes back to normal.
If this accurately describes your problem you can quit looking.
Do a search for EITMS or Engine Idle Temp Management System for more information.
This is as I understand is merely for rider comfort. But since Harley lawyers are always on the lookout for lawsuits maybe they were afraid that they would get sued for rendering riders sterile due the the excess heat in the groin area. ;-)
Old 10-03-2011, 12:48 PM
harleycharlie1992
doesn't appear to be the issue here, bike would have cooled off slightly just during his swapping stuff, to allow both cyls to fire again for at least a minute or two so cyl shut off shouldn't be activating at this time, especially at startup. if it is there is a problem with ecm
Old 10-03-2011, 05:10 PM
Sailrider 1's Avatar
Sailrider 1
Sailrider 1 is offline
My 07 Road King had the exact symptoms as the original posters bike. It would run fine for a while,maybe even half a day then the rear cylinder would quit firing. Then it would run fine for while again and repeat. It did this intermittently for a couple of weeks before we finally chased it down to a bad ECM.
Old 10-03-2011, 05:23 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
What year did HD start utilizing the Parade Mode on the rear cylinder, my 2011 does it all the time at idle?
Old 10-03-2011, 06:36 PM
harleycharlie1992
09 for sure, think 08 had it too dont hold me to the 08 one though
Old 10-03-2011, 07:31 PM
ernster500's Avatar
ernster500
ernster500 is offline
Default Bad ECM?
Wouldn't a bad ECM throw a check engine code though?
Old 10-03-2011, 08:01 PM
Sailrider 1
Yep, on my bike it threw a check engine code, but as soon as the rear cylinder started firing again the check engine light went off. It did leave a historical code for rear cylinder misfire and coil open.
Quick Reply: Rear cylinder is not firing
