Iron 883 problem
Old 09-26-2011, 01:52 PM
ghost0704's Avatar
ghost0704
ghost0704 is offline
4th Gear
Default Iron 883 problem
I just 3000 miles on my bike and I rode it from Ft. Bragg, NC to Warner Robins, GA this weekend. Rode it around town before I go on deployment and my engine light comes on. The rpms r raising up on and everytime I try to shift down it seems it doesn't like it and I had to keep it in 3rd gear just to keep it moving and when its in neutral the rpms start to raise up. It seemed it was about to stall out several times when I was heading back home. I had to shut it off every time I stopped and the rpms keep raising up on. I finally made it home and let it set for awhile and it still does the samething even in neutral. I know the it needs oil but I don't think thats the problem with it. I think it's the throttle cable but not 100% on that. I just started riding last year and didn't have any problems with it until today, so anyone know what the problem is?
Old 09-26-2011, 02:00 PM
barrygreen's Avatar
barrygreen
barrygreen is offline
Check for codes, flip you run switch on, hold in the odometer button on the speedo, turn key on, spedo needle will sweep then you will see letters on the milage display, push in and hold button on speedo when the P is flashing and it will display codes. You can scroll thru the letters and check each one for codes by momentary pushing button.
Old 09-26-2011, 02:03 PM
barrygreen's Avatar
barrygreen
Old 09-26-2011, 02:14 PM
ghost0704's Avatar
ghost0704
4th Gear
I got for codes for the P and everything says none and no rep.
Old 09-26-2011, 02:28 PM
barrygreen's Avatar
barrygreen
You got a P code? What is it
Old 09-26-2011, 02:32 PM
ghost0704's Avatar
ghost0704
4th Gear
P0108 Map Sensor Failed High Carb
P0108 Map Sensor High
P0108 Map Sensor High EFI
P0131 Front Oxygen Sensor Low
P0152 Rear Oxygen Sensor High
P0505 Loss of Idle Sped Control EFI
Old 09-26-2011, 02:39 PM
barrygreen's Avatar
barrygreen
Check all the ground wire connections and battery connections first, especially the one on the inner side of the primary by the starter.
Old 09-26-2011, 02:48 PM
ghost0704's Avatar
ghost0704
4th Gear
They all look fine to me but I am not mechanic and not very knowledgeable on motorcycles. It shouldn't be acting like especially its still new.
barrygreen's Avatar
barrygreen
After you check all that try disconnecting battery for a few min then reconnect ECM could just be having a brain fart, my last bike acted up and had all kinds of codes and a battery disconnect fixed it.
Old 09-26-2011, 03:03 PM
barrygreen's Avatar
barrygreen
If it's new that's what the warranty is for 
My other bike was 6 months old when it acted up and like I said the battery disconnect fixed it.
You might look behind the air cleaner housing at the connections on the throttle body, the one closest to the air box is the idle control motor and behind that is the map sensor ( on top of the intake itself)
Quick Reply: Iron 883 problem
