'11 48 Seat Removal
Old 09-26-2011, 09:18 AM
TexFF's Avatar
TexFF
TexFF is offline
Default '11 48 Seat Removal
I'm @ work on a 24 hr shift, don't have my manual & I'm wanting to remove my seat to see what I'm working w/on a seat swap. I tried google but only found videos & my work computers block youtube. Besides the screw on therear fender, how do I remove the stock seat on my 48? Thanks.
Old 09-26-2011, 09:23 AM
sioux565's Avatar
sioux565
sioux565 is offline
That's it! Pretty simple.
Old 09-26-2011, 09:30 AM
HERE's Avatar
HERE
HERE is offline
I believe you just remove the screw out the fender the sort of lift up the rear and pull backwards at the same time and it'll come right off.
Old 09-26-2011, 09:41 AM
JeffKill's Avatar
JeffKill
JeffKill is offline
Remove the screw, push the seat forward, pull up, then back.
Here's what it looks like underneath the seat. Pushing the seat forward, then up first removes it from the center post (you'll see it when you get the seat off). Once you feel the seat come off of the center post, don't be afraid to really pull on it. It's a snug fit up under the tank.
TennesseeMustangPerf's Avatar
TennesseeMustangPerf is offline
You will need to remove the screw, then push the seat forward while pulling upward. This will release the bolt in the middle of the seat. Then pull the seat backward and it will come free.
Old 09-26-2011, 09:46 AM
Originally Posted by JeffKill
[/IMG]
Beat me to it.
Old 09-26-2011, 09:59 AM
TexFF's Avatar
TexFF
TexFF is offline
That was easy! I removed the back screw but it still felt snug but did what y'all said. Thanks! To install a spring seat, do you use the front bolt closest to the tank to mount the hinge/bracket onto?
Old 09-26-2011, 10:09 AM
Most bolt to the fork bracket that is welded to the tank and bolts to the frame.
Old 11-08-2011, 12:58 PM
orangecrush's Avatar
orangecrush
orangecrush is offline
Thanks Jeff, Harley must have changed the way they remove the seats (the push forward and then pull back). I tried to remove the seat this morning and couldn't. Once I looked at your pic, it was obvious then.
Thanks again,
Mark
Old 11-08-2011, 08:13 PM
barrygreen's Avatar
barrygreen
barrygreen is offline
So what, no step by step updates? Pics???
Quick Reply: '11 48 Seat Removal
