Any drawbacks to Gear driven cams?
Old 09-25-2011, 01:05 AM
Sledge Hammer's Avatar
Sledge Hammer
Sledge Hammer is offline
Default Any drawbacks to Gear driven cams?
I have an '04 Ultra with about 22,000 miles on it now and now that winter is approaching I thought it might be a good idea to check out the cam tensioners. The hydraulic tensioner is about $400+. Since you can get an Andrew's 26G gear driven cams for less than that, it would seem like it would make sense. You get the benefit of added power and no issues with cam chain tensioners anymore. Am I missing something?
Old 09-25-2011, 01:55 AM
$tonecold's Avatar
$tonecold
$tonecold is offline
Received 1,741 Likes on 931 Posts
$400 for the cams and the gear drive? The gear drive alone is usually $400. Before you spend your money you need to check the runout on your crank. If it is more than .003 inches the gear drive system will not work correctly. It will howl. You can buy conversion cams that use the late model oil pump and hydraulic tensioners for about the same money and you get the advantage of the better oil pump.
Old 09-25-2011, 07:52 AM
6 gun's Avatar
6 gun
6 gun is offline
Received 1,743 Likes on 980 Posts
I had the gear drive cams on my 2000 dyna,
and i loved them. I wish that my 07 crank
was as strong as yours because I would
have them again.
Old 09-25-2011, 08:02 AM
Jinks's Avatar
Jinks
Jinks is offline
'06 & earlier run out *shouldn't* be a problem, but check it before you buy the gear drive cams. If you're within tolerance, then gear drive cams are a good idea. If you're out of tolerance, or marginal, compare the price to the '07 & later hydraulic tensioned cam setup. It appears to be as reliable as gear drive, & more tolerant of run out.
Old 09-25-2011, 08:13 AM
'05Train's Avatar
'05Train
'05Train is offline
The runout on my '05 Night Train was .005, so I ended up with a 103 in it.
Gears are nice. I like the sound, and there's no tensioners to ever worry about. That said, if your crank's not too far out, go with the Andrews conversion.
Old 09-25-2011, 08:26 AM
Sledge Hammer
Thanks for the replies guys. I see the error of my thought process. I was looking at the J&P catalog and see that the cam goes for $320. I seem to have overlooked the fact that it requires the S&S gears. Sounds like it still might be the way to go if the run out on the crank is OK, but it isn't as cheap as I thought.
Old 09-25-2011, 10:12 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
I had the 26G's in my 95" built motor.No issues.
Old 09-25-2011, 10:22 AM
Strat HD's Avatar
Strat HD
Strat HD is offline
I have had S&S geardrive since 02. Can't even hear em. Running a Fueling oil pump too. 50 lbs. of pressure at highway speeds, 25 at idle.
Old 09-25-2011, 10:24 AM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,546 Likes on 3,057 Posts
My 2000 has the strong crank so I went Gear Drive with the Andrews 26g's and LOVE IT.
Bought the complete kit, ( cams, gears, new inner bearings and gasket,) for $561.00 from North Shore Cycles via E-Bay.
Only noise issue is the gear 'ticking' which only occurs at idle and when hot, otherwise it purrs.
Old 09-25-2011, 06:37 PM
dawg's Avatar
dawg
dawg is offline
Received 2,954 Likes on 1,711 Posts
Gears set up properly are great. As some have mentioned, the crank runout needs to be within spec (.003 or less, preferably .002 or less) and you need to check backlash and go with an oversized or undersized gear as appropriate. The Andrews 26 likes 9.5 compression. I ran an Andrews 26g with a 95" with bigboyz ported heads at 9.5:1 in my 04 and it was great.
Quick Reply: Any drawbacks to Gear driven cams?
