1998 sportster wiring diagram?
Old 09-16-2011, 09:42 AM
tomlescal's Avatar
tomlescal
tomlescal is offline
Default 1998 sportster wiring diagram?
anybody have the wiring schematic for 1998 1200 sporster?It won't start.Problem is when key is on only the headlight lights up.Seems to be wiring.I know to check battery cables.Trying to help some poor kid fix his bike.
Thanks Tom
Old 09-16-2011, 09:55 AM
Sharkman73's Avatar
Sharkman73
Sharkman73 is offline
Check out Rinnie's Harley Davidson on-line and click on the OEM parts finder. You will find everything you want to know there.
You might want to check your starter and system relays for corrosion before you do anything else...just had a relay problem with my '07. Take it out, clean the corrosion off it with some sand paper, but di-electric grease on it and re-install. If it is corroded, I would replace it.
Old 09-16-2011, 09:56 AM
Sharkman73's Avatar
Sharkman73
Ronnie's, not Rinnie's..
Old 09-16-2011, 10:34 AM
WVHogRider's Avatar
WVHogRider
WVHogRider is offline
Are you turning the key all the way on and not stoping at the ACC position? In ACC, the lights will come on, but do nothing when you try to start.
Old 09-16-2011, 10:48 AM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
Try here:
http://www.google.com/search?q=1998+...rlz=1I7ADFA_en
Old 09-16-2011, 07:56 PM
golden101's Avatar
golden101
golden101 is offline
2nd Gear
Try checking the wiring behind the headlight. I have an 86 1100 that had a start problem and found a bad wire there.
Old 07-30-2020, 05:20 AM
Andy from Sandy's Avatar
Andy from Sandy
Andy from Sandy is offline
Received 3,732 Likes on 2,397 Posts
Meant for a different post, hey ho!
Wiring diagram - https://serviceinfo.harley-davidson....w%3Fid%3D62670
Roadrage1996
04-22-2017 09:13 AM
89325iturbo
General Topics/Tech Tips
04-28-2014 11:34 AM
REDSOX2758
04-24-2013 09:25 PM
lightu
05-08-2008 09:11 PM
lilpork
04-12-2008 08:10 AM
Quick Reply: 1998 sportster wiring diagram?
