CV-Performance tuner kit -- one mans opinion
Old 09-08-2011, 03:33 PM
JonnyD's Avatar
JonnyD
JonnyD is offline
Thumbs up CV-Performance tuner kit -- one mans opinion
Well, I completed the switch, from a S & S Super G back to a stock CV, a while back, and here is my experience/conclusion so far........
The Kit was very easy to install, and instructions as to what jets to use were spot on. I've heard many who swear by the sporty needle, but decided to use the supplied CV-Permance kit as a whole. The carb now starts, runs, and performs so much better than the S & S. Not saying the S & S is a bad carb, just too much carb for my 80 EVO.
I have ran it up and down the freeway, on the curvy back roads, and around town, and it runs like a champ. My only complaint, is with the E-Z adjust air screw, and that's only because I burned my hand adjusting it when the bike was hot. After I figured out how to get my hand in there without burning it, I was ok with it. Definitely easier than trying to get a screw driver in there and turn it.
The carb is much more forgiving to adjustments, than the S & S was. And though I may not have it dialed in, perfectly, it runs great and I have no complaints.
I am in no way affiliated with CV-Peformance, and actually found them on another bike forum. Then I started researching, and made my decision to give the kit a try. I'm sure there are others out there that are just as good, I'm just giving my .02 on their particular kit.
Hope this helps anyone on the fence about doing an upgrade to the CV carb's.
Old 09-08-2011, 04:19 PM
Doug S's Avatar
Doug S
Doug S is offline
Yeah, I also like the CV, very straightforeward piece of engineering with no real bad traits or hidden issues. The PO of my bike or his indy was a major tinker-er, my carb has every kit and option known to mankind, thunder jet, dynajet kit, that slide thing, heck the needle is adjustable and he still had a couple washers under it...LOL
But, although it's a bit fussy until the engine is warmed and it doesn't like cold weather starts, it flat out runs away with the bike when you get on it. It behaves a little like kicking a fourbarrel holley with that thunderjet when you get on it at high speed. I got a great deal on a brand new CV this spring and decided to try it, got it jetted and adjusted, bike ran just fine and got good mileage to boot. After a moonth of boredom I put the old one back on and started living again...LOL
Glad your bike is running great for you..
D
Old 09-08-2011, 05:08 PM
Spanners39's Avatar
Spanners39
Spanners39 is offline
I had heaps of probs with setting up my Dyno Jet kit but damn it gave some good power!
Old 09-08-2011, 09:39 PM
rizzo's Avatar
rizzo
rizzo is offline
Received 4,620 Likes on 2,094 Posts
If you really want to wake up that CV, take a look at the Wood Performance High Capacity bowl kit. I still get around 45 MPH with a stage 3+ 80" Evo build.
Wakko47
Exhaust System Topics
03-09-2012 09:29 PM
motoxhd21
01-20-2012 11:08 AM
Donhd04
09-24-2010 08:10 AM
byg twyn 55
05-23-2010 01:10 PM
Mr1986FLST
Shovelhead
04-14-2009 08:49 PM
Quick Reply: CV-Performance tuner kit -- one mans opinion
