Check Engine light not coming on at ignition
Old 09-05-2011, 06:35 PM
Plaidfinger's Avatar
Plaidfinger
Plaidfinger is offline
Default Check Engine light not coming on at ignition
Hope this is an easy one. I just bought my 1st harley in years, a 2012 Dyna Wide glide with security system. when the bike is on the side stand and I turn on the ignition switch, the check engine light comes on as it is supposed to, however when I am on the bike and it is upright with the red security light on and I turn on the ignition switch, sometimes, the check engine light does not come on at all or comes on for 1-2 seconds. Is this normal?
Old 09-06-2011, 03:33 PM
1HD1C's Avatar
1HD1C
1HD1C is offline
not sure if im reading you right but the check engine light comes on until the
fuel pump builds pressure then goes out.
you should always wait until the light goes out before cranking if the bike is stock.
Old 09-06-2011, 05:04 PM
Plaidfinger
The problem is that there are times when the light does not come on with my stock bike. It is only when I have raised the bike off the kickstand and the red security light is lit. If I turn on the ignition with the bike on the kickstand, it lights up every time. Is this a result of the security system? Anyone else with the security system notice this or be willing to sit on your bike, then turn the ignition on while the red security light is lit and see if the check light still lights up?
Old 09-06-2011, 05:15 PM
Garyk's Avatar
Garyk
Garyk is offline
I don't have the security system but I would assume it has to do with the anti-theft. From what I have read these systems are motion activated.
Old 09-06-2011, 05:48 PM
Dynaglide68's Avatar
Dynaglide68
Dynaglide68 is offline
The check engine light is supposed to come on wait till it goes off to push the start button , as far a the red security light >>>>>>>>> ( CHECK OUT YOUR OWNERS MANUAL )
Old 02-13-2013, 05:54 PM
lmyers's Avatar
lmyers
lmyers is offline
I have a 2013 fatboy lo and noticed the same. Not sure if it's normal or not...did you get any further info on this?
Old 02-13-2013, 05:58 PM
8upguitarman's Avatar
8upguitarman
8upguitarman is offline
Mine seemed like it didn't do that before. Just had new Stator put in and mine does that now. They come on, start, go off for a second, key then Engine light come on for a few seconds and they go away. No security system.
Runs fine now.
stan60
07-29-2017 02:27 AM
Kaycee
08-14-2012 10:33 PM
Plaidfinger
09-05-2011 02:39 PM
doomie19
03-27-2007 01:24 PM
cyfxdwg
03-28-2006 12:44 AM
Quick Reply: Check Engine light not coming on at ignition
