Tour Pak on 2012 Street Glide
Old 09-03-2011, 04:33 AM
Strick120's Avatar
Strick120
Strick120 is offline
Default Tour Pak on 2012 Street Glide
I purchased a tour pak that was on a 1999 Classic. I am currently having it painted to match my Street Glide. I have the 4 point docking system installed on the bike. I will be purchasing part number 53276-09A (Detachable Rack).
Question, will the tour pak mount on this rack or will some modifications have to be made? The tour pak came with a tubular frame mount from the Classic.
Any help would be most appreciated.
Old 09-03-2011, 06:34 AM
springer 03's Avatar
springer 03
springer 03 is offline
You will have to redrill some holes to make it work. No big deal. Take your time and be aware of placement. I had to buy a spacer bar from the dealer for the forward mount. I don't remember the part # but the parts guy can look it up. It was about 6 inch wide and a 1/4 inch thick.
Old 09-03-2011, 08:21 AM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
If you look at the picture posted by CigarCritic in reply 8 of this thread, you'll see the difference in hole patterns for '09 and newer models, and '08 and older models:
https://www.hdforums.com/forum/touri...reetglide.html
The "spacer" referenced previously is shown in the pictures posted by TexasFatBoy and you can locate the part no. for this in his thread, reply 2 in the above thread.
If you want to mount the tour pak directly to the tour pak rack you've ordered, you'll need the spacer--it levels the bottom of the tour pak for mounting to the rack. And you'll need to drill four holes in the bottom of your tour pak to match the holes in the rack. Although TFB's reply is for a chopped tour pak, the chopped tour pak retains the heavily molded bottom of '05 and older King tour paks. '06 and newer tour paks have an essentially flat bottom so the spacer is not needed.
Also, if you choose to replace the backrest pad with a newer version, you can, but the mounting holes in the lid will cause the newer backrest pad to be higher than it would if you used a '97 or newer lid/tour pak. You can drill new holes---same pattern just 3/4" or so lower than the OEM holes--for a better fit.
Good luck with your project.
Carl
Old 09-04-2011, 06:33 AM
Strick120's Avatar
Strick120
Springer and Harleypingman,
Thank you for the replys. Your information has helped me a lot. Thats why I come here.
Strick
Old 09-04-2011, 06:38 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
And...if you have to plug some holes from all the mounting/drilling - head to your local hardware store & get the rubber plugs. Easiest way to cover them up & seal from elements. Post some pics when you've got it on the bike.
Steve Valentine
03-19-2019 11:57 PM
Ozark Azz
2014-2023 Touring Models
11-01-2015 12:01 AM
ballbreaker69
12-17-2011 09:54 PM
BirchwhiteHD
04-12-2011 07:04 PM
roadking07
11-15-2006 05:33 PM
Quick Reply: Tour Pak on 2012 Street Glide
