blowing ignition fuse, won't start
Old 09-01-2011, 11:28 AM
screamineagleharley's Avatar
screamineagleharley
screamineagleharley is offline
Default blowing ignition fuse, won't start
2001 heritage softail, I started it up yesterday morning and backed it out of the garage, then realized I forgot something in the house, so turned it off. When I got back to start it up, it wouldn't start. Checked the fuses, and the ignition fuse was blown, put a new fuse in it, hit the start button and it instantly blew the ignition fuse. Put another new fuse in, same thing. Blew 4 or 5 fuses.
Any advice as to whats causing this? I have the service manual, I'd much rather figure this out on my own than taking it to the dealer at $70/hr labor
Thanks
Old 09-01-2011, 11:42 AM
r0cker's Avatar
r0cker
r0cker is offline
A short
Trouble shoot it. Does it blow when you turn key to ignition or when you actually push the starter?
Old 09-01-2011, 12:04 PM
screamineagleharley
it blows when I actually push the start button, I tried it again just now, with the seat off and as soon as push the start button, you can see the fuse instantly blow
Old 09-01-2011, 12:19 PM
oct1949's Avatar
oct1949
oct1949 is offline
Thinking its a short in Ur wiring or starter some where.
Has the bars been changed out or still stock?
Old 09-01-2011, 02:55 PM
SMF's Avatar
SMF
SMF is offline
I think a ground might have loosened up somewhere bro
Old 09-01-2011, 06:38 PM
screamineagleharley
yes its got 18" ape hangers, but no work like that has been done on the bike in a long time. I did give it a very thororgh washing a few days ago,
think maybe something got wet? and thats causing it?
thank all of you for the advice so far, I'm going to check for any loose ground wires
Old 09-01-2011, 06:40 PM
screamineagleharley
also forgot to mention, it does have a screamin eagle ignition module but that was installed on it several yrs ago
I changed out the black swithes about 2 or 3 months ago for the chrome switches but everything has worked fine since then
so its just weird how it started right the other morning and then 3 mins later this happened
Old 09-01-2011, 06:58 PM
Blk and Chrome's Avatar
Blk and Chrome
Blk and Chrome is offline
chances are the problem is in the bar wireing or the swtich
Old 09-02-2011, 07:25 AM
cwsharp's Avatar
cwsharp
cwsharp is offline
+1 on that one.
Old 09-07-2011, 09:56 PM
mcleod9's Avatar
mcleod9
mcleod9 is offline
The start button wires are "pinched" in the brake resevoir/lever clamps that go over your handlebar. Open them up and try it. You probably can fix the problem by grinding out the half-moon area where the lines go thru. Also, grind out the lower half of the swith mount halves.
Quick Reply: blowing ignition fuse, won't start
