Fairing Pouch
Old 08-26-2011, 09:07 PM
Roadrunner14's Avatar
Roadrunner14
Roadrunner14 is offline
Default Fairing Pouch
Has anyone installed the "three pocket fairing pouch" on their Triglide? If so, how is it installed? Thanks!
Bob
Old 08-26-2011, 09:17 PM
BinIdaho's Avatar
BinIdaho
BinIdaho is offline
Bob
Yes, I installed the 3-pocket windshield bag....pretty simple if I could do it. Take off the windshield, slide the 3-pocket bag on (should be the one with slots just like windshield), put windshield back on and tighten the screws.
Old 08-26-2011, 09:20 PM
pettifogger1's Avatar
pettifogger1
pettifogger1 is offline
Yep, have one on mine. Installs just like a windshield. Take out the three windshield screws and replace them with the new longer ones and spacers that come with the pouch. Slip pouch in behind windshield and tighten screws. It's a no brainer and takes five or ten minutes at most.
Old 08-26-2011, 09:31 PM
Roadrunner14
Perfect. Thanks for the info! That's what I like about this group...answers!
Bob
Old 08-27-2011, 06:26 AM
T K Glider's Avatar
T K Glider
T K Glider is offline
I have the T-Bag brand very easy to add and a real plus.I haven't done mine yet but riders Velcro a GPS on a flap and works quite well.
Old 08-27-2011, 07:12 AM
msocko3's Avatar
msocko3
msocko3 is offline
Bob
One word of caution is don't get wild when you tighten the bolts back down for the outer fairing. There are brass inserts that are molded into the inner fairing which can be pulled out if you use a heavy hand. The torque for those fastener is no more than 32 in/lbs.
Old 08-27-2011, 05:56 PM
halfbreed's Avatar
halfbreed
halfbreed is offline
I installed one on my 2011 and, like the others have already said, a very easy install. However, I am somewhat disapointed in the storage capacity on the two end bags. because of the shape, they are not as good as those which have a flat bottom, but that's my opinion. They proabably have more cu. inches of storage, but I could fit more "stuff" in the older style I had on my Ultra.
Old 08-27-2011, 08:59 PM
DaveLaBenne's Avatar
DaveLaBenne
DaveLaBenne is offline
I have one too. Use it to hold the back pocket stuff and clip my iPod to it. I wouldn't hang anything heavy off it though. A gps may be too much for it. The left pouch is snapped on, could use that spot for a heavy item.
Old 09-02-2011, 11:26 AM
CWDoc115's Avatar
CWDoc115
CWDoc115 is offline
1+ what he said, & add the chrome windshield strip while you are at it...
Old 09-02-2011, 02:07 PM
Mr. Wizard's Avatar
Mr. Wizard
Mr. Wizard is offline
Administrator
Received 2,035 Likes on 1,103 Posts
Be sure to place a soft side velcro strip under the droop type bags. They will lay on your inner fairing and scratch the paint right off the fairing.
Quick Reply: Fairing Pouch
