Lowering a 1992 Heritage Softail with a Progressive drop in Kit
Old 08-26-2011, 01:03 AM
mdunn's Avatar
mdunn
mdunn is offline
Default Lowering a 1992 Heritage Softail with a Progressive drop in Kit
Ok, I spent over 1 hr searching the forum for a good how to pictures and instructions thread on installing a Progressive Drop in Kit for my 1992 Heritage Softail. I want to Drop my front end by 2 inches. Does anyone have pictures of step by step instructions on how to do this? How about a thread that i might have missed for this Softail?
My other question is, do I wait untill I have the rear lowering Shot Gun Shock kit before I do the front or can you do the front first without screwing things up? Is it wise to do both at the same time?
Old 08-26-2011, 10:19 AM
jreichart's Avatar
jreichart
jreichart is offline
Check out youtube, they usually have some pretty decent videos on this stuff. As for whether to do both at the same time, the answer is yes. It's usually OK to lower the rear without the front, but a bad idea to lower the front without the rear. It has to do with changing the trail measurement which is a vital part of the handling and stability of the bike.
Old 08-26-2011, 10:24 AM
mdunn's Avatar
mdunn
mdunn is offline
I was on you tube as well last night, even on progressives Channel..nothing came up that is the same as my Softail Heritage. Looks like i cant go low untill i either:
A: Just buy the Shotgun Kit
B: Get some progressive 422's and use those for now.
Mike
Old 08-26-2011, 10:28 AM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
WARG has pics on his blog I believe. http://chasinwhitelines.blogspot.com/
Drew
Old 08-26-2011, 11:00 AM
jreichart's Avatar
jreichart
You can lower the rear with the cheapo bolts too. I did mine, and it rides fine to me. It's a good enough solution to hold you over till you get the shotguns or 422's.
Old 08-26-2011, 11:24 AM
truckin's Avatar
truckin
truckin is offline
if you have a 21 up front with a 2 inch drop you will be ok without doing the rear thats what i just did it leveled it out
Old 08-26-2011, 02:55 PM
mdunn's Avatar
mdunn
mdunn is offline
I might just pull the trigger on a set of 422's to tide me over, I hate spending that much cash when you can save for the real deal
Drew, i searched his Blog, where is it?
Mike
Old 08-26-2011, 10:12 PM
oct1949's Avatar
oct1949
oct1949 is offline
Phew,,!!!!!!!!!!!!!!!!! U Cal-la-fornians.. are in a rush.....
To do it right it seems like U need the Air system and front springs..
read a little more...
Us Mid Easteners haven't gone that far Yet..
Old 09-09-2011, 10:50 PM
mdunn's Avatar
mdunn
mdunn is offline
I am still trying to find someone who lowered their early Softail in the front with a Drop in kit, like from 1992-99. Has anyone ever done this before? Pictures? Anything at all? I added the rear 422 shocks on tonight along with the new rims and tires. Tomorrow is the front end and this Drop in kit.
Old 09-09-2011, 11:34 PM
mdunn's Avatar
mdunn
mdunn is offline
Just to confirm, I have to remove the front fender, calipers, wheel, etc to drop the tubes down below the tripple tree right?
Mike
brucepancake
02-18-2019 04:58 PM
dsalazar63
Softail Parts
03-06-2018 03:40 PM
lionsqrne
Air Suspensions
08-07-2012 06:48 PM
lionsqrne
09-14-2007 05:30 AM
Quick Reply: Lowering a 1992 Heritage Softail with a Progressive drop in Kit
