Drive Belt Questions
Old 08-23-2011, 12:51 AM
mikeallenbrown's Avatar
mikeallenbrown
mikeallenbrown is offline
Default Drive Belt Questions
On average, about how long does a belt last? ...on a stock 1200. I understand that the life of a belt depends on many things...riding conditions, how hard you ride, etc. I'm just looking for an educated guess.
Second question .... I remember seeing on the internet some "emergency belt splice kit" ....anyone ever use one? To temporarily get you home. Is it a good idea to have or is it junk?
Thanks!
EDIT: ...last question: OEM belts good enough? ...or is there a "better" "stronger" belt you'd recommend?
Old 08-23-2011, 05:50 AM
turn8a's Avatar
turn8a
turn8a is offline
I'm close to 52000 miles on a 2004 1200r with the stock belt. And the belt still looks good.
Old 08-23-2011, 06:09 AM
grbrown's Avatar
grbrown
grbrown is offline
Hi Mike, from another Brown! There is no simple answer to your question. I've just replied to another current post about a broken belt, so there is some attrition along the way. I have replaced one of my belts when it suffered stone damage, which eventually began to spread, so I replaced it to be on the safe side.
Even early belt drive bikes have been recorded going round the clock on the original belt, in other words over 100k miles. The solution is to keep the belt properly adjusted (apparently being too tight is the common cause of breakages) and keep the guards in place, to keep out debris.
I don't think you will find a stronger belt. Harley made a sidecar belt when they used 1 1/2" belts on the touring bikes, but since they fitted the later spec 1 1/8" narrow belt they no longer do. So I think we must conclude the latest belts are already super strong!
As for an emergency belt kit, how much stuff should we carry around with us, just in case? Much easier to carry a roadside recovery card! In 21 years of belt-drive Harleys I have not been left on the roadside with a broken belt. OMG, what have I said.....
Old 08-23-2011, 04:51 PM
SportyPig's Avatar
SportyPig
SportyPig is offline
My original belt broke at 63,000 miles. Other than a clean straight break, the belt looked perfect. It was at the proper tension.
I have heard of guys getting 80,000 - 100,000 miles on a belt.
Old 08-23-2011, 09:15 PM
John_K's Avatar
John_K
John_K is offline
The recommended tension is way too tight. If you lift the bike and remove the rear shocks the swing arm will stay up from the belt tension. It is actually preloading the shocks. It's also likely putting undue stress on the output shaft bearings and possibly skewing the engine in its mounts if you have an '04 or newer 'rubbermount.' It should be loosened off just enough to allow the swingarm to fall through the 'tight spot' under its own weight. Make sure the alignment is not changed by turning the adjusting nuts equally on both sides. That's my opinion ...your mileage may vary.
gerald martin
13
10-17-2021 06:21 PM
bikemiser
08-19-2011 06:12 PM
strange1
01-04-2009 11:07 AM
clayman
10-15-2006 03:08 PM
DieHard
05-02-2006 08:01 AM
Quick Reply: Drive Belt Questions
