Stripped allen bolt!!!!
Old 08-22-2011, 10:05 AM
BAKERiSM's Avatar
BAKERiSM
BAKERiSM is offline
Default Stripped allen bolt!!!!
I just bought a used 07' Nightster and decided to change all the fluids. Oil was going great untill I tried getting off the primary chain inspection cover. The allen bolt was already stripped so I tried tinkering with it and couldn't get it and as a last resort decided to use a screw extractor. After getting the extracter in there with my spirits high... It breaks off inside. Now I'm not sure what to do... Does anyone have any insight into this problem? Any help would be greatly appreciated!!!
Old 08-22-2011, 10:39 AM
sioux565's Avatar
sioux565
sioux565 is offline
On my 09, the inspection cover uses Torx bolts. That could have been your first issue, unless the previous owner put allen head bolts there instead.
Can you get the cover off or no?
Old 08-22-2011, 10:48 AM
parabellum_9x19's Avatar
parabellum_9x19
parabellum_9x19 is offline
By 'breaks off inside' do you mean the head of the bolt twisted off, leaving only the shaft of the bolt, flush or below flush into the threads???
IF YOU CANNOT get the cover off:
If that is the case, and you've never done this before, take this to a professional who is VERY skilled at doing these jobs. Ideally, find a machine shop, not just any normal mechanic.
They are going to have to drill out the shaft of the bolt, VERY carefully, clean out the remaining threads, and chase the old threads out with a tap.
If they can't get the old threads out clean, they will have to bore out the hole one size bigger and then tap new threads, or insert at a Helicoil to the OEM thread size.
Either way, you want an expert at this kind of thing to do this job for you.
IF YOU CAN GET THE COVER OFF:
Get the cover off and find someone who is a skilled welder, have them weld on a new head to the exposed threads (carefully!!!!). Use the new head to remove the bolt. If this one snaps off also, revert to the steps above.
Old 08-22-2011, 01:31 PM
Aaron48's Avatar
Aaron48
Aaron48 is offline
Take a Dremel and cut a slot in the head so you can use a flathead screwdriver to take it out. If you have a flat head screwdriver that has a hex shaped shank that would be a plus, then you could use a small adjustable wrench to help turn it.
Old 08-22-2011, 04:27 PM
Booey424's Avatar
Booey424
Booey424 is offline
I also have used this method with good results.
Old 08-22-2011, 04:41 PM
BlockHead96's Avatar
BlockHead96
BlockHead96 is offline
I just striped the allen head off my Ness Big Sucker air filterr, used a dremel to cut the head off and was able to use pliers to back out the rest of the bolt.
Old 08-23-2011, 04:33 PM
SportyPig's Avatar
SportyPig
SportyPig is offline
No big deal. I had one of those bolts that was broken for over 10,000 miles. It never leaked. Next time I needed to take the primary cover off, then I could just easily get the broken portion of the screw off.
A way to keep this from being a problem in the future is to use anti-seize compound on those screws before installing
Old 08-23-2011, 05:22 PM
jag1886's Avatar
jag1886
jag1886 is offline
There's a special place reserved in HELL for the guy that invented screw extractors. If it ever happens to you again just take a 1/4 drill bit and drill the head off the screw remove the cover and the remaining bolt will screw out with your fingers. Been there!
Old 08-23-2011, 05:46 PM
PeteRock's Avatar
PeteRock
PeteRock is offline
+1
If the head is still on. I've had luck with these
http://www.sears.com/shc/s/p_10153_1...4&blockType=G4
If the head broke off then your probably going to have to drill and tap. So you might as well take primary cover off to prevnt getting drilling debri inside your case anyway. Once the cover is off you might be able to screw out from inside with nice set of vise grips. If you broke off extractor chances are your going to have to drill.
Old 09-06-2011, 10:34 PM
BAKERiSM's Avatar
BAKERiSM
BAKERiSM is offline
You guys rock! Thanks for getting my back to me! I'm new to this so I never knew anyone wrote me back untill now ha... But after breaking off 2 screw extractors inside the bolt I dremeled out a giant slot for a flat head screw driver and finally got it out like Aaron said... I definitely jacked up the the inspection cover but thats a 20 dollar fix! Now the bike is running great. Thanks again everyone for all the tips!
Quick Reply: Stripped allen bolt!!!!
