need oil line routing
Old 08-22-2011, 08:36 AM
82flh's Avatar
82flh
82flh is offline
Default need oil line routing
hey guys built a custom i got an oil filter mounts to motor on a 1999 evo crate motor......no oil cooler.... someone explain simple oil routing for this?...where does main feed go?...return from filter? vent?...i got 3 lines pretty simple to plumb ...oil filters throwing me off?.....hmmmmm anyone?
its the chrome aftermarket filter mounts to case with rubber hose type.....
THERES NO OIL COOLER....NO OIL COOLER!
Old 08-22-2011, 09:03 AM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,689 Likes on 1,341 Posts
Put the filter in the return line from the oil pump to the tank.
Old 08-22-2011, 10:39 AM
95yj's Avatar
95yj
95yj is offline
Your picture shows a Softail, so I'm assuming you have the Softail battery cooker oil tank. Staring at the side of the oil tank from the starboard side of the tank, the left most line is the main oil feed (actually separated from the other two) and then the middle is the vent and the right most is the return from filter.
Old 08-23-2011, 08:49 PM
82flh's Avatar
82flh
82flh is offline
i have a round oil tank....feed at bottom then on top i have vent and return....thats it thats all........the inner on filter goes to oil pump but that all i got so far....the outter oil filter one goes to where?...... also its a stock evo i have one fitting at bottom one at top i believe top is breather going to vent correct?....
Old 08-24-2011, 02:39 PM
95yj's Avatar
95yj
95yj is offline
Here's from the HD Service Manual of a FL/FX although all the Evos are pratically the same with the exception of what the oil tank looks like. Let me know if you need more clarification.
Old 06-26-2018, 09:18 PM
WiSeNhEiMeR's Avatar
WiSeNhEiMeR
WiSeNhEiMeR is offline
How about a CHART / DIAGRAM for an EVO era DYNA with the Oil Pan under the Transmission ?
When I got the bike the transmission was OUT of the Bike
I'd LIKE to be sure where to PLUMB the oil lines when I reassemble the BIKE
NO ... the REPAIR MANUAL for a 1995 DYNA seems to skip the OIL LINE "routing"
Any help or URL / LINK would be appreciated
Old 07-26-2018, 04:07 PM
WiSeNhEiMeR
Default Anybody have an OEM Service MANUAL with the DYNA (EVO) diagram ?
The DYNA is totally different than any OTHER H-D Engine / Transmission configuration
I Need a Routing DIAGRAM for a 1995 DYNA (EVO) 5-Speed / OIL PUMP / Oil Filter / Motor / OIL Line /
I'm attempting to locate an OEM H-D SERVICE MANUAL for a 1995 DYNA
So far the only help I been given was a DIAGRAM for a Softtail (totally DIFFERENT animal)
Old 07-26-2018, 10:20 PM
Beemervet's Avatar
Beemervet
Beemervet is offline
1995 Dyna Factory Service Manual
Pay no attention to Clymer or Haynes versions.
Old 07-26-2018, 11:00 PM
Kenny Appleton's Avatar
Kenny Appleton
Kenny Appleton is offline
Stage IV
Are the two rigid lines still there from the filter? If so there is only one way for the pump to hook up to the filter. There is a vent line inboard of the pump, this goes to the top of transmission as does the return line from the filter. The feed line is from the bottom of pan to the face of pump body.
Old 06-07-2019, 01:13 AM
newzealand's Avatar
newzealand
newzealand is offline
Greetings from New Zealand. I also mam, after a 1995 OEM H-D SERVICE MANUAL for a 1995 DYNA. Did you have any success, is it something youd be happy to share, Id be hella grateful. Best Dave 95FXD
777PIC
Oil Archive (no new posts)
12-10-2012 05:41 AM
lowrider79
07-30-2012 07:20 PM
janiharley
02-17-2010 04:23 PM
jbwftx
Exhaust System Topics
12-31-2009 08:48 AM
mrbarbque
02-05-2008 04:35 PM
Quick Reply: need oil line routing
