2005 XL883C sluggish
Old 08-17-2011, 05:50 PM
pryncessbonbon's Avatar
pryncessbonbon
pryncessbonbon is offline
Stage II
Angry 2005 XL883C sluggish
My 2005 XL883C is sluggish. Recently she feels like someone is behind me tugging on a rope, or like I am pulling a skier on choppy water or dragging a load of rubber tires like cans on your wedding day. Any suggestions on what the problem is? I have some ideas from reading other threads, but nothing that really fits.
Old 08-17-2011, 06:06 PM
diablo666's Avatar
diablo666
diablo666 is offline
Put new spark plugs in first.If that doesn't help my bet would be the carb needs cleaned or rebuilt.If you changed exhaust and air cleaner you will need a rejet.
Old 08-17-2011, 06:53 PM
pryncessbonbon
Stage II
I changed the spark plug during a tune up a month ago when the old wasn't bad, just old, and I didn't have this trouble until after. I checked it before I installed it to ensure the gap was correct.
Old 08-17-2011, 06:57 PM
gfburke's Avatar
gfburke
gfburke is offline
Having new plugs is great, but that doesn't really mean they are both "good". Could be a faulty plug.
Also, have you tried to shoot some carb cleaner in the intake while shes running? almost sounds like a jet is clogged or ya, spark isn't really making it.
Old 08-18-2011, 03:37 PM
jcshultz13's Avatar
jcshultz13
jcshultz13 is offline
put your old plugs back in if it still does it then you no its not the plugs as the issue.if that straightens it out maybe they sold you the wrong plug.they done that to me before.it happens.lol if that doesn't take care of it itcould b a fuel issue.
Old 08-18-2011, 03:44 PM
cHarley's Avatar
cHarley
cHarley is offline
Are you sure you don't have a brake dragging?
Old 08-20-2011, 01:48 AM
John_K's Avatar
John_K
John_K is offline
If the brakes were dragging that much they would be smoking hot after a couple of blocks. If that's the case, then it's time to rebuild the master cylinders (and pronto!) and flush the system.
Is it running rich?
Is there a noticeable gas smell?
How is the throttle response?
Do the symptoms change after it is warmed up?
Old 08-20-2011, 03:34 AM
TennesseeMustangPerf's Avatar
TennesseeMustangPerf is offline
I agree. Give some new plugs a shot.
Originally Posted by John_K
Is it running rich?
Sounds like the OP is in good hands. All the same questions I would ask. This will tell you a lot about where it is coming from. Could be anything from a bad plug to a weak spark or low compression. I would also ask, how is the idle?
Old 08-20-2011, 03:35 AM
Also, post pics of the plugs when you get them out of the bike. They are gonna tell a lot.
Old 08-23-2011, 11:55 PM
John_K's Avatar
John_K
John_K is offline
If you can rule out problems with the carb the next most likely culprit will be the crank position sensor about $60 and a 10 minute fix.
Common problem on early rubbermounts.
ThrillKilla
07-28-2016 05:04 PM
radio915
Shovelhead
13
05-27-2016 10:32 AM
Funky Monk
09-05-2012 08:20 AM
Razorback Rob
12-31-2008 09:19 AM
wolf1477
Ironhead
27
06-03-2006 12:54 AM
Quick Reply: 2005 XL883C sluggish
