1994 Ultra classic starter solenoid replacement
Old 08-16-2011, 08:18 AM
trigger1911's Avatar
trigger1911
trigger1911 is offline
Default 1994 Ultra classic starter solenoid replacement
my 1994 Ultra has been giving me some problems starting. i would hit the starter button and the solenoid would just give a loud click. hit the button several times then it would start. I replaced the starter relay and it was fine for 3-4 weeks and now it is doing it again. If I hold the starter button down and hit the solenoid with a block of wood-it starts. Battery is fully charged and does not drop below 11.2 volts when starting. I want to replace the solenoid but can I do this without removing the starter. From what I see, the entire primary side needs to be dismantled to remove a starter. Thanks!
hardheaded
Shovelhead
07-01-2013 12:11 AM
Snoman
11-24-2012 11:26 AM
boneyrooster
06-16-2010 08:39 PM
old bagger
06-16-2010 11:45 AM
sweatbee
08-27-2008 07:32 PM
Quick Reply: 1994 Ultra classic starter solenoid replacement
