how do you remove the front fork
Old 08-14-2011, 06:59 PM
FLHXDAN's Avatar
FLHXDAN
FLHXDAN is offline
Default how do you remove the front fork
I have a 2009 street glide and need to change the upper slider cover. I have everything removed including the pinch bolt but things are not free yet. Is there a trick to this?
Old 08-14-2011, 08:22 PM
hojones's Avatar
hojones
hojones is offline
Have you removed the nut on top? Tap the fork down shoud come out.
Old 08-14-2011, 08:32 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
there's a spring under that nut, get a rag over the top and some help or you could have a piece of metal flying, looking to hit the most expensive thing in your garage.
manual?
mike
Old 08-14-2011, 09:10 PM
geezer glide 56's Avatar
geezer glide 56
geezer glide 56 is offline
Remove the fork cap 1 3/8 wrench the spring in the fork tube is captive under this cap so there is no worry about flying parts...The fork tube should slide out after removing the cap.
Old 08-15-2011, 06:50 AM
FLHXDAN's Avatar
FLHXDAN
FLHXDAN is offline
I loosened the nut on top and removed the pinch bolt on the side. I tapped on top of the nut with light hammer while holding a board on the nut. Maybe I just need to hit it harder. As far as the spring under the nut, it seems to turn very easy. Will there be a lot of tension on this spring?
Old 08-15-2011, 06:55 AM
Fatboy Brian's Avatar
Fatboy Brian
Fatboy Brian is online now
No, as long as you just remove the top nut. There will be no spring come out.
Old 08-15-2011, 07:04 AM
EasternSP's Avatar
EasternSP
EasternSP is offline
Received 21,914 Likes on 8,432 Posts
I will presume you have removed your front wheel, fender and calipers.
Old 08-15-2011, 12:21 PM
jerseyjeff62's Avatar
jerseyjeff62
jerseyjeff62 is offline
2 words Service Manual!
Old 08-15-2011, 02:27 PM
RK4ME's Avatar
RK4ME
RK4ME is offline
Received 2,211 Likes on 1,380 Posts
The "trick" is to use a Harley Davidson Service Manual when working on your Harley Davidson. If you don't use a manual, you WILL screw your bike up in some way.
Old 08-15-2011, 07:51 PM
FLHXDAN's Avatar
FLHXDAN
FLHXDAN is offline
Had to use a bit larger hammer and hit on the large nuts on top. There was a rust build up where the shock goes thru the tree holes. Before I re install the forks the holes will be thoroughly cleaned and a light film of anti sieze applied.
Thanks jerseyjeff62 and RK4ME for your professional advice, you guys are really full of yourselves.
Maxdog2
EVO
04-12-2014 09:50 PM
hell hound
01-16-2010 04:35 PM
Theo
11-01-2009 04:29 PM
roysays
12-20-2008 06:46 PM
Jetstream
01-04-2007 10:00 PM
Quick Reply: how do you remove the front fork
