80 inch EVO motor
08-14-2011, 02:57 PM
80 inch EVO motor
I have a 97 fxstc and have installed a new high flow aircleaner and a thunderslide kit. I have plans to install a single fire ignition but my question is what other upgrades have you guys made to your Evo motors ??
08-14-2011, 09:45 PM
Never owned one, but most guys I know that have them do cams..
With cams, pipes and A/C those suckers will move out and kept up with the 88's and 96er's
08-15-2011, 05:28 AM
There's an Evo classic forum on here. Might want to post this thread there for a better response.
08-15-2011, 09:45 AM
Address the cam bearing. There are not many weak points on an Evo, but the cam bearings often fail between 30 and 50K. Cheap fix unless you wait.....
________________________
08-15-2011, 11:13 AM
Shave the head a little, shorter head gasket, andrews cams, ignition, jet the carb, and a good set of pipes and it will have no issues keeping up. While your in there, maybe re-ring the stock pistons.
08-16-2011, 09:13 PM
Also, change the lifters around 40K. I know this from experience. Do this when you change the cam bearing.
mikeyhd
Shovelhead
09-25-2017 07:22 PM
bigwalt
04-27-2014 05:39 PM
gnafin
EVO
04-11-2014 04:21 PM
jurob
06-21-2009 08:01 AM
fryeca
Custom Models
08-19-2008 12:14 PM
2008,
80,
80evomotorreviews,
build,
engines,
evo,
exahust,
harley,
inch,
make,
motor,
motors,
primary,
sale,
softail
