Mobil 1 10W40 in primary
Old 08-14-2011, 12:19 AM
Chunker's Avatar
Chunker
Chunker is offline
Default Mobil 1 10W40 in primary
I have a couple of gallons of Mobil1 10W40 sitting in my garage that were intended to be used on Kaw I no longer own. Not suitable for the Mustang, 5W20, or the diesel pickup, so I figured it would work in the primary of the HD. It's the good stuff, safe for clutches. I realize it's probably overkill using synthetic, but it's in the garage and already paid for. Seems a waste to use it inn the lawn mower or generator.
Old 08-14-2011, 07:37 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
Not if you want to increase the engine life by doing regular maintenance.
Old 08-14-2011, 07:41 AM
Stiggy's Avatar
Stiggy
Stiggy is online now
Received 5,537 Likes on 3,054 Posts
Run 10w-40 dino in mine. Synthetic is indeed overkill, but yours is 'free.' Heck Yes!
Old 08-14-2011, 08:23 AM
skydude426's Avatar
skydude426
skydude426 is offline
I have Mobil one 10w40 v-twin oil in my primary. The clutch works great and I figure the synthetic oil is good for the chain, bearings and adjuster shoe. It will also not break down from high temps as fast as dyno oil. It is connected to a very hot running air cooled engine. I just figure if synyhetics are availabe for the application, why not give my ride the better fluid. Just my two cents.
Old 08-14-2011, 08:30 AM
soft 02's Avatar
soft 02
soft 02 is offline
Not good for air cooled stationary engines. A straight 30w would be better in lawn mowers and generators. I would use it in the primary too
Old 08-14-2011, 09:56 AM
beary's Avatar
beary
beary is offline
The manuals of All my 4 stroke air cooled lawn equipment motors say a multigrade synthetic 10w30 is fine. I can't imagine a 10 w 40 not working, expecially in our 100 plus heat.
Beary
Old 08-14-2011, 10:07 AM
Sam2010's Avatar
Sam2010
Sam2010 is offline
I run used 20/50 In my mower. I use the Mobil 10/40 in primary.
Old 08-14-2011, 02:41 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
Bike and Diesel 10W40 is ok for Primary. Auto 10W40 has friction modifiers that cause slippery slip clutch engagement as well as having lower base metals which provides wear protection. The base metals are lower in auto oil by industry agreement as a way to extend the life of the catalytic converters to the EPA 10 year goal.
Old 08-14-2011, 04:14 PM
beary's Avatar
beary
beary is offline
Originally Posted by speakerfritz
Bike and Diesel 10W40 is ok for Primary. Auto 10W40 has friction modifiers that cause slippery slip clutch engagement as well as having lower base metals which provides wear protection.l.
Are you sure about that? There is no seal on 10w40 that indicates friction modifiers like you see on the 10w30 oil.
Beary
Old 08-14-2011, 04:30 PM
RK4ME's Avatar
RK4ME
RK4ME is offline
Received 2,210 Likes on 1,380 Posts
I believe Mobil1 10w40T is what Mobil recommends for Harley primaries. I ran Syn3 in mine for 50K miles and prefer it to the Formula+ that's in there now.
Quick Reply: Mobil 1 10W40 in primary
