Rocker box torque specs & sequence
Old 08-13-2011, 12:03 PM
JefFLH's Avatar
JefFLH
JefFLH is offline
Default Rocker box torque specs & sequence
I have a buddy's '99 Heritage out in the shed with the rockers torn off both cylinders due to some pretty good leaks on each. I am replacing all gaskets from the head all the way up after I check to make sure nothing is warped. Hopefully this will take care of his leaks. It's a pretty nice bike when it's not covered in oil. I don't have a Softail service manual, Touring guy myself, could anyone be able to tell me the torque specs and sequence for reinstalling these and getting him back on the road? Mucho thanks in advance.
Jeff
Old 08-13-2011, 12:31 PM
Sgt_Jim's Avatar
Sgt_Jim
Sgt_Jim is offline
is that an Evo or a Twin Cam? on the Twin Cams the torque value is 15-18ft/lbs.. but i don't have an order of tightening for you
Old 08-13-2011, 03:57 PM
roadkingharry's Avatar
roadkingharry
roadkingharry is offline
Like Sgt Jim said, is this an Evo or Twin cam?
If it's a Twin cam and you mean the rocker housing boxes:
The torque for those is: 120-168 in/lbs.
For purposes of these directions, left side (LS) means the bolts on the side with the spark plug,right side (RS)means the bolts on the intake side,front (front)means toward the front wheel,rear (rear) means toward the rear wheel.
There are 3 bolts on the front and 3 bolts in the back of each "box". So the sequence is:
Front cylinder: RS rear, LS front,LS rear,RS front,middle rear,middle front
Rear cylinder RS front,LS rear,LS front,RS rear,front middle,rear middle
This is for the rocker covers :
Front cylinder: LS middle, RS Middle, LS rear,RS front,LS front, RS rear
Rear cylinder: LS middle, RS middle,LS front,RS rear, LS rear,RS front
As mentioned: 15-18 ft./lbs
Do you know how to install the rocker arm support plates? If not, post for advice so you don't bend the push rods. The support plate bolts get tightened to 18-22 ft/lbs but both lifters of the cylinder being serviced must be on the base circle of the cam. Basically, the 4 rocker arm support plate bolts get tightened diagonally.
Disregard all directions as it looks like you have an EVO
Old 08-13-2011, 07:48 PM
JefFLH's Avatar
JefFLH
JefFLH is offline
Thanks guys. It's a Evo. Ran by Laconia HD to get him a service manual, but they were out. Had to order him one. Just so we're all on the same page here, I have all 3 pieces of the assy. off, right down to the top of the heads. The plate that mount on top of the head with the rockers in them , the middle spacer and the covers. I am going to check everything out put it all back together tomorrow. Keep it coming if it looks like anyone missed anything. I found my old manual from my '85 Evo, just want to make sure nothing changed. And yes, I know to make sure I'm on the base circle before tightening the rocker arms down.
Old 05-13-2022, 04:09 PM
Charles F's Avatar
Charles F
Charles F is offline
Do you guys know what the rocker cover torque specs would be in inch pounds if they were 15 to 18 ft lb ?? I only have an inch pound torque wrench
Old 05-13-2022, 07:38 PM
hattitude's Avatar
hattitude
hattitude is offline
Received 7,397 Likes on 4,010 Posts
1 foot-pound equals 12 inch-pounds
So multiply foot-pounds by 12, to get inch-pounds
15 ft-lbs = 180 in-lbs
18 ft-lbs = 216 in-lbs
Old 05-13-2022, 10:26 PM
Charles F's Avatar
Charles F
Awesome , thanks!
Steevo12683
Engine Mechanical Topics
08-04-2017 07:23 PM
andyp
06-22-2017 04:40 AM
HOGILAC
03-03-2016 07:39 PM
Bologna
06-01-2015 09:28 AM
roaddog
Exhaust System Topics
01-23-2011 09:22 PM
Quick Reply: Rocker box torque specs & sequence
