Is my crank position sensor bad?
Old 08-12-2011, 08:59 PM
racedvl's Avatar
racedvl
racedvl is offline
Default Is my crank position sensor bad?
2001 FLHPI fuel injected police roadking. 62950 miles.
Quick back story, yesterday (Thrusday) I took the bike on a long ride south to see the Chicago Bears training camp. On the ride down on 2 seperate times the engine lamp kicked on when getting up to speed after a stop sign. soon as I was at cruzing speed, it went off. It only did that twice. Didn't change the way it ran or nothing. Got to camp watched the pratice for about 2 hours, bike started fine and started my ride home. Stopped about 20 min into the ride and gassed up. no problems. Started on the long part of my ride and about 15 miles from home the bike at a stand still waiting for a light, just straight up died. Would not restart, even after cooling down.
So I disconnected the crank position sensor, hooked it up to my dvom, set it to ac/dc v and here's the reading after cranking it over.
Vid here.....
http://youtu.be/8IRJT6DP0_8
Seems low right? Bad sensor? From what I can find, most people that have a bad crank sensor, can cool it down, and get it running again. Not here.
On a side note, I tried to get the codes out of the speedo, and seems to have gotten 41 & 44. But that does not make sense from what I can find for codes. Any ideas folks? Thats for any input. Jason
2001 FLHPI injected police roadking.
Old 08-12-2011, 09:02 PM
racedvl's Avatar
racedvl
racedvl is offline
Also, I have a factory tach, and when I crank it over it does read about 300 rpm's.
Old 08-13-2011, 12:48 AM
Eyespy's Avatar
Eyespy
Eyespy is offline
Location: Southern California High Desert, here and there....
41 is the crank position sensor code and 44 is the bank angle sensor code
Old 08-13-2011, 09:34 AM
racedvl's Avatar
racedvl
racedvl is offline
Looks like I might need to test the bank angle sensor as well. Anyone have the testing procedure for it?
Old 08-13-2011, 12:29 PM
larsfum's Avatar
larsfum
larsfum is offline
From what I understand the Bank Angle Sensor is integrated in the Turn Signal Control Module. If it is the BAS, you should be able to cycle the Stop/ Run switch, and it should start. You may also want to check your main circuit breaker.
Old 08-13-2011, 01:00 PM
racedvl's Avatar
racedvl
racedvl is offline
Hhhmmmm...... I wonder if my turn signals / flashers are working.......
Old 08-14-2011, 11:07 AM
racedvl's Avatar
racedvl
racedvl is offline
Ok, I guess the crank sensor needs to be plugged in when testing, it tests fine. Soo back to basics. Got out the spark tester... I have spark. Put a long screw driver on the injectors...they are clicking. Soo... Sprayed some brake cleaner down the throttle body.... And walla!! It starts.... So im gonna dive into the full gas tank (damnit) and see whats up.....
Old 08-14-2011, 07:22 PM
racedvl's Avatar
racedvl
racedvl is offline
Broken fuel line in the tank. She's a runner now.
Old 07-17-2013, 05:23 PM
07bagger's Avatar
07bagger
07bagger is offline
where did u get the new fuel line? I think mine might be bad...mine would run fine down the road and then just die..but it kind of dieseled little bit before that..did it like 4-5 times during a 2 hour ride my father in law said to check battery cables...idk.
Grey_Beard
04-13-2019 01:40 PM
dennisj1988
07-27-2018 01:50 PM
blueglide88
09-06-2017 07:30 PM
07JakeelwoodHD
09-27-2013 07:58 AM
jb bill
Exhaust System Topics
03-18-2010 07:19 PM
Quick Reply: Is my crank position sensor bad?
