Tallest rim and widest tire
Old 08-12-2011, 08:22 PM
CLEAR's Avatar
CLEAR
CLEAR is offline
Default Tallest rim and widest tire
What is the tallest rear rim and widest tire you can put on a stock Street Bob without spending big money? I think Ive seen a few with a 200 tire. Also would a 21 inch front wheel fit?
Old 08-12-2011, 09:17 PM
p51bombay's Avatar
p51bombay
p51bombay is offline
What year? Later(10+) models will take an 18x6 with a 200 without any changes other than maybe relocating your siginals. Mine fit completely without mods, I already had the lights moved so no experience whether you will or won't
Old 08-12-2011, 09:35 PM
nkauf21's Avatar
nkauf21
nkauf21 is offline
I'm running an 18x5.5 rear with 180/55 Metzler ME880. Some have fit a 200 so it's possible. I'm also running a 21x2.15 with 90/90 Metzler front.
Old 08-12-2011, 11:37 PM
JaronB's Avatar
JaronB
JaronB is offline
Here's a Jireh cycles 21x3.25 with a 120/70/21 up front. You can also use your stock hub and spokes.
For stock hub and spokes
https://www.hdforums.com/forum/dyna-...nd-spokes.html
Old 08-13-2011, 12:09 AM
gartec81's Avatar
gartec81
gartec81 is offline
Part#
30-50
Description
RIM 21X3.25 40 SPOKE
this rim laces to our stock hub??
Old 08-13-2011, 12:27 AM
JaronB's Avatar
JaronB
JaronB is offline
Originally Posted by gartec81
Part#
30-50
Description
OOOP!! Yes I meant 3.25 and yes stock hub and spokes work. You just lace it 1 over 3 and it gives you the distance you need. Check out the thread I posted above. Jstreet is still running this set up. I still used new spokes just because I already bought them and it's a PIA to return them from an internet source. But they were still 19" spokes and were the same length as the stockers.
Old 08-13-2011, 10:47 PM
CLEAR's Avatar
CLEAR
CLEAR is offline
Mine is an 07. It actually has the alloy wheels, which I dont care for. Looking for something different
Old 08-13-2011, 11:29 PM
jmeiers's Avatar
jmeiers
jmeiers is offline
I run the following:
Front - 21x3.5 w/ 120/70/21 Metzeler
Rear - 18x5.5 w/ 200/50/18 Metzeler
You are not going any wider than this without some serious modification.
Old 08-14-2011, 09:20 AM
CLEAR's Avatar
CLEAR
CLEAR is offline
Looks like Jirehs is a pretty cheap place to buy some 21 and 19 inch wire wheels. They dont show any 80 spokes though.
Old 03-20-2012, 07:20 PM
jeffrob07's Avatar
jeffrob07
jeffrob07 is offline
bump.
07FXSTC
02-26-2017 11:10 AM
lee christopher
07-21-2015 09:51 PM
Lasher66
02-11-2015 02:29 PM
suntadz
09-22-2010 08:23 PM
HoosierHarley
08-15-2009 10:22 AM
Quick Reply: Tallest rim and widest tire
