2011 FXDB (Street Bob) Handlebar Q...
Old 08-06-2011, 07:39 PM
jkirke's Avatar
jkirke
jkirke is offline
Default 2011 FXDB (Street Bob) Handlebar Q...
So I'm looking at purchasing and installing taller Apes on my '11 FXDB. The stock bars are 1" correct? Why when I search on the web for new apes they're all 1 1/4"? Will the 1 1/4" apes fit without any additional mod to the stock risers?
Thanks in advance,
jkirke
Old 08-06-2011, 10:27 PM
iDodgimus's Avatar
iDodgimus
iDodgimus is offline
Stockers are 1" yup, and I doubt that 1.25 inch bars would work with those risers
Old 08-06-2011, 11:08 PM
Bspike1's Avatar
Bspike1
Bspike1 is offline
not at all... the new SB's have the risers integrated into the upper tree. to go to bigger bars you have to change the upper tree as well.
Old 08-07-2011, 02:16 AM
Tat2u's Avatar
Tat2u
Tat2u is offline
Depends, alot of the 1.25 bars are stepped down to 1" at the clamp area.
Old 08-07-2011, 02:39 AM
JaronB's Avatar
JaronB
JaronB is offline
There are a lot of 1" bars you just have to look. Sometimes in the description you have the option to choose 1" or 1.25" of the same bars. I think there are quite a few running 1.25" bars on the SB without the step down. You'll just have a bigger gap between the top clamp and the lower clamp. But I think they had to lower their fork tubes down a little to clear the bottom of the bar.
Old 08-07-2011, 02:57 AM
Tat2u's Avatar
Tat2u
Tat2u is offline
quote
"I think there are quite a few running 1.25" bars on the SB without the step down. You'll just have a bigger gap between the top clamp and the lower clamp."
um no..you can't use an 1.25" bar in a standard street bob triple tree that has th intergrated risers unless that bar is stepped down to 1.000" to fit the clamps
Old 08-07-2011, 06:30 AM
jkirke's Avatar
jkirke
jkirke is offline
Thanks for all the great info and help. I'll continue my internet search for 1" apes!!
Old 08-07-2011, 08:50 AM
bikridr69's Avatar
bikridr69
bikridr69 is offline
i put 1.25 inch bars that are stepped down to 1. inch in the riser. with the 1.25 inch bars (on the outside) you have to slide the tripple trees up just a bit. check out brcustomcycle.com for some bad *** bars
Old 08-07-2011, 11:45 AM
JaronB's Avatar
JaronB
JaronB is offline
Originally Posted by Tat2u
quote
That's why I said I think! I did some searching and everybody that I found has the step down, but they still had to lower the fork tubes depending on the bars or get lonerindustries risers.
Old 08-07-2011, 07:07 PM
blueangel73's Avatar
blueangel73
blueangel73 is offline
If you want to go with the 1.25 that steps down to 1.00 at the clamp you can either lower your fork tubes as already stated or go to lonerindustries.com and order a 1" riser that is designed to work with the Street Bob's stock riser. That is what I have on mine. Look in my albums for picks. They were only $70 I believe. You other option is a new top tree with new risers.
Quick Reply: 2011 FXDB (Street Bob) Handlebar Q...
