timing
Old 08-04-2011, 10:50 AM
harley7316's Avatar
harley7316
harley7316 is offline
Default timing
Hi was wondering i have the timing @35 full advance and high compression motor getting pinging i want to retard the timing abit i was told rotating the plate counterclockwise will retard the timing so when i lossen off the studs and stick a screwdriver in the adjusting knotch and trun screw driver counter clockwise it looks to me that it is moving the timing plate clockwise is that correct?Thanks
Old 08-04-2011, 11:29 AM
KingPinVinny's Avatar
KingPinVinny
KingPinVinny is offline
To retard it, turn to the right, clockwise.
Old 08-04-2011, 05:04 PM
miacycles's Avatar
miacycles
miacycles is offline
The timing cup runs off of the cam which is turning in the opposite direction of the engine. To retard it you need to turn it counter-clockwise.
Old 08-04-2011, 05:19 PM
KingPinVinny
He is right my mistake, im so use to setting a mag on mine.
31choptop
Panhead
05-03-2013 09:27 AM
harley7316
EVO
07-15-2011 04:18 PM
harley7316
EVO
05-28-2009 12:03 PM
supr2nr
Ironhead
05-05-2008 08:47 AM
mojo2go
08-14-2007 06:21 PM
Quick Reply: timing
