09 Ultra Fuel Filter Change (EASY!)
Old 08-02-2011, 04:51 PM
PappyUSMC's Avatar
PappyUSMC
PappyUSMC is offline
Default 09 Ultra Fuel Filter Change (EASY!)
I did some reading at https://www.hdforums.com/forum/touri...9-touring.html
It has Pics so us Jarheads can even use it!
So anyway, back to my post....
I bought the fuel filter from local Dealer for $17, they quoted me $122 installed.
Here is what I did....
Unbolted the spine on the tank (2 bolts)
Moved it to the side.
Used the spark plug wrench that came with my Harley kit as my "blunt" object
Tapped it with my torque wrench three times and it popped off.
Removed the fuel housing/pump assembly, kinda pain in the *** to manuever correctly. Unhooked one line to break pressure.
Remover/replaced filter.
Put it all back together.
Harley was going to charge me $100 to put it in..... I did it in 20 minutes. Harley is a rip-off.
One of the easiest tasks I have done on the Harley to date.
I highly recommend learning to do it yourselves.
Side note: I replaced it due to my HD hesitating and sputtering. I neglected to replace it for 50k. I learned my lesson.
It was BLACK.
Old 08-02-2011, 05:38 PM
lipster's Avatar
lipster
lipster is offline
But when you do it yourself, your hands smell like gas.
Oh, wait, that's men's cologne. Women love it!
Old 08-02-2011, 08:41 PM
Jags93's Avatar
Jags93
Jags93 is offline
That "blunt object" should be non-ferrous so you don't create a spark.
Old 08-02-2011, 08:48 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
you have 50K on an 09?
Old 08-02-2011, 09:02 PM
PappyUSMC's Avatar
PappyUSMC
Well.... 48K+ will be 50K by the time this trip is over in two weeks.
Old 08-02-2011, 09:09 PM
PappyUSMC's Avatar
PappyUSMC
Good point. Didn't think of that part. I will adjust for future filter changes.
Thanks brother.
I probably shouldn't have been smoking while doing it. (Jk)
Old 08-02-2011, 09:27 PM
DPete's Avatar
DPete
DPete is offline
Big Kahuna HDF Member
Received 1,729 Likes on 1,302 Posts
Ha ha found my old thread did ya? glad if it helped save you $100, now about the user fee, J/K
Old 08-03-2011, 12:50 AM
cdestuck's Avatar
cdestuck
cdestuck is offline
Gotta save this thread.
Old 08-03-2011, 05:17 AM
PappyUSMC's Avatar
PappyUSMC
Brother, no joke, you saved me $100+ bucks. If we were IVO each other, I would definitely buy you a couple rounds.
Between youtube, fixmyhog.com and this forum, I have saved thousands of dollars that I would have otherwise sunk into stealer maintenance.
No joke.
Old 08-03-2011, 05:25 AM
y2kflhr's Avatar
y2kflhr
y2kflhr is offline
we need to find out if the 2012 has a different filter, because the spec is now change at 100k
Quick Reply: 09 Ultra Fuel Filter Change (EASY!)
