speedometer problems
Old 07-14-2011, 11:15 PM
tonedef's Avatar
tonedef
tonedef is offline
Stage I
Default speedometer problems
My 2000 883 had a low battery and would not start. I used a battery charger and tried to jump it. Battery too dead. Charged up battery and now speedometer is not working neither is the odometer. I cleaned the sensor still no speedo. I uses the self diagnostic mode on the speedo and d08 showed. All of the things I have read state that the speedometer needle should sweep once entering the diagnostic mode. Mine does not. Did I fry the speedo when I tried jumping my bike with a bead battery?
Old 07-15-2011, 06:01 AM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
tonedef, I would pull both cables off the battery and unplug the ECM. Let it set for a few and connect it back up in that order and see what results
TormentedH-D
07-19-2014 11:18 AM
Mixter
03-31-2012 06:07 PM
ridrkg
03-18-2012 11:45 AM
Scruggs
02-26-2008 07:22 AM
flvrider
VRSC Models
08-24-2006 08:41 PM
Quick Reply: speedometer problems
