120R: Barnett Scorpion or Bandit Sportsman clutch?
Old 06-30-2011, 09:53 PM
fxstc1999's Avatar
fxstc1999
fxstc1999 is offline
Default 120R: Barnett Scorpion or Bandit Sportsman clutch?
I've reading a lot on the forum about clutch slippage with various clutches used on the 120R. I'm needing to order one for my 120R setup on my 08' Street Glide, but I want to make the right choice. I've read good feedback on the Barnett Scorpion and the Bandit Sportsman. Any pro's or con's with either of these clutches on a big cube motor? I know I can install a MRC to relieve the clutch pull but I hear they make it difficult to find neutral. Any advise or suggestions would be greatly appreciated. I need to pull the trigger quickly on the clutch.
Old 06-30-2011, 10:04 PM
arealinvestor's Avatar
arealinvestor
arealinvestor is offline
I don't have much knowledge of the Bandit ,or Barnett ,but I run the Rivera Pro with the gold spring on my 124ci with the VPC on top of it.So far so good.Initially I had slippage with weaker springs & without the VPC.The clutch pull is a little heavier ,but the easy ramp was not needed in my opinion.The SE clutch is much harder!!!
Old 06-30-2011, 10:35 PM
0796bob's Avatar
0796bob
0796bob is offline
I have had no problems with my screamin eagle clutch,132 hp and 123 tq.
fxstc1999's Avatar
fxstc1999
I've also been considering the Aim VPC with the stock H/D clutch, but I think this would be borderline for slipping. I'm hoping to hear some good feedback on either the Scorpion or the Sportsman. This route would be cheaper than buying the VPC and trying it with the stock H/D clutch and it slip then have to buy another clutch to replace the stock one to run along with the VPC.
Old 06-30-2011, 10:40 PM
fxstc1999's Avatar
fxstc1999
I've reading different threads that the clutch slippage with certain clutches run with the 120R is not necessarily noticable by the "seat of the pant" but on the dyno.
Old 07-01-2011, 12:16 AM
Hydroboy35th's Avatar
Hydroboy35th
Hydroboy35th is offline
subscribed!
Old 07-01-2011, 12:19 AM
Hydroboy35th
I heard the AIM VPC92 with a 380lb spring will work!
Old 07-01-2011, 04:18 AM
SE120RG's Avatar
SE120RG
SE120RG is offline
Just use the SE race clutch, you'll get used to the pull. It is adjustable to the amount of TQ the engine produces. No slippage for me
lee123
10-26-2019 08:39 AM
Lotaluck
06-22-2017 03:12 PM
Firemn17
General Topics/Tech Tips
07-21-2016 12:25 PM
beammeup
The Dyno Room
05-10-2016 08:43 AM
texacon
07-18-2011 07:32 PM
Quick Reply: 120R: Barnett Scorpion or Bandit Sportsman clutch?
