Tire wear indicator
Old 06-29-2011, 07:00 PM
lastbike's Avatar
lastbike
lastbike is offline
Default Tire wear indicator
I have a 07fxstc and need help telling when i need a new rear tire based on how the wear indicator should look like? Any help is appreciated
Old 06-29-2011, 07:34 PM
Gman in NC's Avatar
Gman in NC
Gman in NC is offline
On the side of the tire near the tread there are little triangles spaced pretty far apart. When you see one of these that is the location of the wear bars. You can find the wear bar in the tread and if it's not below the tread it's time to at least start thinking. You can squeeze another thousand out of it but if you're planning a trip I'd say do it before you leave.
Old 06-29-2011, 09:39 PM
In Memoriam Citoriplus's Avatar
In Memoriam Citoriplus is offline
May our Moderator Rest in Peace
If I remember right my FXSTC's rear tire had little Harley emblems molded into the top of the wear bars.
If you can still see them your OK, for now.
But if you just see the bars are even with the rest of the tire surface, its time to get a new tire.
I don't make a habit of beating the snot out of my bike and tires but they still only lasted about 9500 miles.
If your riding style is average they may last longer.
But even if your really easy on them I wouldn't expect to get too far past the 10,000 miles mark.
Old 06-30-2011, 09:07 PM
lastbike's Avatar
lastbike
lastbike is offline
thanks 4 the help i still have the hd shield showing i m just trying 2 get some more mileage untill i get new tires. i only get 4500 2 5000 on a rear tire and i dont drive aggressive.
Old 06-30-2011, 09:13 PM
soft 02's Avatar
soft 02
soft 02 is offline
As soon as I hit the wear bars I only had about 400 miles to spare. When you see second rubber you have like 100 miles till you get to the steel belt. Ive gone through roughly 15 rear tires.
Grizzx2
03-11-2024 07:26 PM
jory434
12-05-2012 11:01 AM
T K Glider
25
08-17-2011 01:04 PM
turkey
08-14-2011 06:38 PM
Cohiba_Joe
05-29-2007 09:37 AM
Quick Reply: Tire wear indicator
