Parade Fan???
Old 06-28-2011, 11:13 AM
myred55's Avatar
myred55
myred55 is offline
Default Parade Fan???
Got stuck in traffic at the entrance to Yosemite Park Sunday. Thought the bike was going to catch on fire!
Thinking about getting a "parade fan" to cool her down when stuck in traffic.
Questions:
Does a fan help to cool down the bike when stuck in traffic?
Which fan would you all recommend? Harley or Lenale or other brand?
Thanks!
Old 06-28-2011, 11:40 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
get the Harley fan. do not use the heat sensor in the kit. wire the relay to the ACC switch instead so you can trun it on and off manually. also, wire the fan backwards. normal wiring brings the air from left to right which results in hot air from your engine being blown into you intake. wired back wards results in air moving right to left and keeps cool air going into your intake. If you have a stage one, take the egg cover off. with the cover on, your getting a lot of engine heated air. Oil cooler is a big help. There's a fan kit for the oil cooler with blows air thru the heat exchnager reguardless of bike speed. the optional harley heat shields seem to help your rider, moreso than helping you. Also, if your bike gets really hot, to the extent it's making chatter noises, replace your engine oil, becuase it's probally now shot.
Old 06-28-2011, 12:20 PM
RockerMike's Avatar
RockerMike
RockerMike is offline
It helps cool it down, but more important is it prevents it from getting so hot. I have the Harley fan and I used the heat sensor, but did not attach it to the air intake - rather it just sits down between the V. End result is the fan comes on earlier and helps keep the temp down.
I have no problem with airflow from left to right.
Old 06-28-2011, 01:08 PM
mtnbkr53's Avatar
mtnbkr53
mtnbkr53 is offline
I used the Lenale on my 2011 Road Glide Ultra 103. It has a manual switch on fan housing (rocker switch) so it is easy to reach to turn on and off as needed. This little jewel really looks good on the bike and delivers a serious amount of air between the jugs! Being stuck in bumper to bumper at Pegion Forge/Gatlinburg for over an hour my oil temp gauge never topped 250* even though the ambient temp was 89*. It does however put a serious amount of scorching air off the right side-- so you have to keep that leg out of the air flow!
Old 06-28-2011, 02:50 PM
myred55's Avatar
myred55
myred55 is offline
Speakerfritz, thanks for your input but what is a egg cover?
Old 06-28-2011, 04:36 PM
speakerfritz
the chrome harley air intake cover. when you go stage one, the back plate of the cover is not used, the back is open, and acts like a parachute to catch hot air off your engine. this causes a convention effect...as new hot air is sucked in, temp rises exponetially as eng continues to heat up and also furthur heats up ambient air, cycle runs away until you engine over heats or your nuts fry.
Old 06-28-2011, 06:22 PM
myred55's Avatar
myred55
myred55 is offline
Is there a different air cleaner cover available that will not catch the hot air or should I just take the egg off and run it with the air cleaner exposed?
Thanks
Old 06-28-2011, 06:35 PM
speakerfritz
Thanks
a lot of folks run it exposed...some get nice looking chrome disc plate and use a rain sock when it rains. I keep mine exposed and have ridden in torrential down pours with no ill effects.
Old 12-20-2011, 08:08 PM
autotechmark's Avatar
autotechmark
autotechmark is offline
Default Day late and a dollar short.
I know this is wicked late but I tried two Lenalle fans. Both worked awesome for the first fifteen minutes of operation and never worked again after that. I contacted Lenalle who charged me half my original cost to replace the motor but the same thing happened. I think I will be doing the Harley fan. Just my two cents.
Old 12-20-2011, 08:42 PM
fabrik8r's Avatar
fabrik8r
fabrik8r is offline
Questions:
Thanks!
They definately work, check out the results in my thread https://www.hdforums.com/forum/touri...tem-again.html
post #1 and # 54, 2black1s posted test data on the Lenale fan also at https://www.hdforums.com/forum/touri...test-data.html
Quick Reply: Parade Fan???
