cruise control not working
Old 06-26-2011, 06:11 PM
jgann's Avatar
jgann
jgann is offline
Default cruise control not working
2002 ultra cruise control not working. the light comes on when you flip the switch, but cruise does not engage. What can I check?
Old 06-26-2011, 06:27 PM
07DDreamHD's Avatar
07DDreamHD
07DDreamHD is offline
The cruise control is very sensitive. Sometimes it may be the connections and sometimes it may require that you go through the set-up procedures that are listed in your manual. Maybe try to go back through the set-up in the manual. If that does not fix the problem, then check your connections.
Old 06-26-2011, 06:31 PM
Lito's Avatar
Lito
Lito is offline
Stage III
I have the same problem. I have checked anything yet let me know what you find out. I have a 2002 rk classic thanks
Old 06-26-2011, 06:34 PM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,537 Likes on 3,054 Posts
Could be as simple as a broken/frayed control cable. I lost one on my 98 Ultra.
Old 06-26-2011, 06:36 PM
Lito's Avatar
Lito
Lito is offline
Stage III
I have a 2002 rk classic with 95 big boar kit, 2 into1 thunder header with power commander. Getting ready to install cams and either doing new hydraulic or gear. Any good or bad info to help me make my mind up. 510 cams is what i was thinking
Old 06-26-2011, 06:37 PM
hd4evr2008's Avatar
hd4evr2008
hd4evr2008 is online now
Received 1,823 Likes on 821 Posts
Old 06-26-2011, 06:38 PM
Neil's Avatar
Neil
Neil is offline
I'm having the same problem with my 02. 07DDreamHD, jgann and I have cable operated throtles. I don't think there is any re-set procedure that I have found. If anyone knows of something I would love to hear it. My prblems started after I installed braided brake lines. The switch lights up, the fuse is good but no cruise (no green "C" on the dash). The brake lights work as they are supposed to when the the brakes are applied. Any thoughts?
Neil
RDMC
Old 06-26-2011, 06:39 PM
vickers1's Avatar
vickers1
vickers1 is offline
Follow your throttle cable from the handlebars. You'll find a switch. Unplug one wire from the switch. Ride the bike and check the cruise. If it works, replace the switch.
Old 06-26-2011, 07:12 PM
07custom's Avatar
07custom
07custom is offline
Is the rear brake light lit all the time? My rear brake switch went, cruise didn't work & the brake light stayed on all the time.
Old 06-27-2011, 12:37 AM
Potato_Potato's Avatar
Potato_Potato
Potato_Potato is offline
Check both brake light switches.
Quick Reply: cruise control not working
