Blacking out your engine, casing
Old 06-25-2011, 04:41 AM
xcore's Avatar
xcore
xcore is offline
Default Blacking out your engine, casing
Hey, I'm sure there are some riders here who blacked out the engine casing.
I'm planning to black out as many things as I can i.e transmission casing, derby cover, primary, sproc cover and so on. Just wondering if I use high temp black spray on them, will it last? Heard that sometimes the heat gets too hot for the spray to stay.
And engine fins too, have anybody tried blacking that out? At a dilemma to try spraying them back first or to send them for powdercoating straight away.
Mario Jad (05-24-2019)
Old 06-25-2011, 07:45 AM
Ta2edShady's Avatar
Ta2edShady
Ta2edShady is offline
I can tell you from experience working in near vicinity of 16 cylinder turbo CAT diesels that your bike isn't going to hit a temp higher than the VHT paint will be good with. That being said, even after all the prep and following of instructions I did with painting mine it is rubbing off where my left heel hits the case. I'll just have to touch it up in the future.
Old 06-25-2011, 07:59 AM
xcore's Avatar
xcore
xcore is offline
How about the fins and engine area? Planning to black them out like how the iron looks like.
Old 06-25-2011, 08:13 AM
trozenhorse's Avatar
trozenhorse
trozenhorse is offline
i just did the same thing, i used the harley textured engine paint, i found the paint expensive and it took a few cans, VHT has a few different types and next time thats the route i will take.....lots of green masking tape!
Old 06-25-2011, 08:23 AM
xcore's Avatar
xcore
xcore is offline
You spray your engine without removing it? Is it hard to get a smooth surface on the fins? There are some hard to reach areas. Anyway I think the harley textured matt black paint is really nice. Did you prime your casings before you sprayed them?
Old 06-25-2011, 01:16 PM
kountry's Avatar
kountry
kountry is offline
VHt ceramic header spray works great did my exhaust and motor
Old 06-25-2011, 04:08 PM
xcore's Avatar
xcore
xcore is offline
For those who sprayed their primary casing, do you remove the casing to spray on spray with it still on the bike? I'm planning to do so but I do not want my bolts to be black. Is it advisable to remove one bolt, spray that area, then screw it back and repeat the steps for all the bolts? At least in this method the casing still stays on.
Old 06-26-2011, 12:30 AM
DocHoliday06's Avatar
DocHoliday06
DocHoliday06 is offline
Hey xcore,
I painted my jugs and casings. I just used a lot of tape and a lot of newspaper. Just pick what paint you want and get a case of beer. Take your time taping everything you don't want to be sprayed, I suggest starting in the morning. Again take your time taping and take your time spraying also.
Old 06-26-2011, 12:34 AM
DocHoliday06
oh and one more thing. I just went ahead and sprayed all the screws so if you want to not paint the screws just tape those.
Old 06-26-2011, 01:06 AM
crazy_walt's Avatar
crazy_walt
crazy_walt is offline
Hey guys i was wondering if i can spray my primary case and my trans case if they are chrome? And i want to spray them black what kinda paint you recomend? I want to it textured. Seeing as i am going to primer my fenders and tank.
Quick Reply: Blacking out your engine, casing
